Engine screaming like it saw something very scary - JeepForum.com
post #1 of 8 Old 10-29-2013, 09:03 PM Thread Starter
TheBootlegger
My 4 cyl just goes nuts when I turn it on.. Loudest screeching, squealing sound evar. I started it for the first time tonight after 4 months of changing a bunch of stuff on it, I expected a rough start, but everytime I turn the key all hell breaks loose. I hear the engine running fine under the loud *** scream though, and it was running great last time I started it. Temperature is under the freezing point most of the time now, and I suspect the serpentine belt or water pump to be the criminals. Is there anything else that could cause such a disturbing, evil, ear shattering sound? Thanks!
note: I started it inside so the squeal might have sounded louder lol
TheBootlegger is offline
post #2 of 8 Old 10-29-2013, 09:07 PM
Hoxie
Hoxie's Avatar
1987 YJ Wrangler
Belts, Check the tension on your serpentine. Even check for wet or dryness.
YJOTM January 2017
Hoxie is offline
post #3 of 8 Old 10-30-2013, 06:30 AM
SeanB95YJ
sounds like one of the accessory drive bearings is gone.... my bet would be on the idler pulley, but COULD be alternator, water or PS pumps.
remove the belt and see if any of the pulleys can be wobbled by hand. they SHOULD be rock solid with no noticeable movement. start with the idler which is the pulley that's just bolted to the block, not driving any motor or pump
Good luck
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #4 of 8 Old 10-30-2013, 09:11 AM
pbmustache
The alternators seizes up all the time after they sit for awhile. Take the belt off and spin the pulleys. You should be able to tell which one is bad or seized.
pbmustache is offline
post #5 of 8 Old 10-30-2013, 11:23 AM Thread Starter
TheBootlegger
Awesome thanks! I'll check it as soon as I got time.
post #6 of 8 Old 10-30-2013, 08:01 PM
ROTTEN
Start it with no belt first. For piece of mind. Just for a minute
I'm new
ROTTEN is offline
post #7 of 8 Old 11-03-2013, 07:35 PM Thread Starter
TheBootlegger
Solved. Alternator was Seized!
post #8 of 8 Old 11-12-2013, 09:45 PM
pbmustache
That's good news @thebootlegger
