Engine running cold - JeepForum.com
post #1 of 2 Old 06-25-2001, 01:32 PM Thread Starter
jmsjeep
Engine running cold
Next issue -
Engine has been running around 110 now not even moving needle. Runs fine but this can't be good long term. My first thought is the thermostat. Is thier any thing else I should look at or test before I drain antifreeze.
Thanks
I wonder were that dirt road goes?
'89 YJ 4 banger all stock, replacing all the worn out guts first, 97 grand cherokee limited
jmsjeep is offline
post #2 of 2 Old 06-26-2001, 07:04 PM
mikeyjph
If the needle's not even moving, you might want to check the gauges first, or the wiring. YJ dashes are notoriously bad, my oil pressure guage is broken, my tach light is out, the 4wd light never comes on and the parking brake light never goes off. Damn, i love my jeep
mikeyjph is offline
92 YJ 2.5 Running too cold ? Restless_Entity YJ Wrangler Technical Forum 12 09-15-2014 11:26 AM
wont stay running when engine is cold shoeshard YJ Wrangler Technical Forum 1 02-10-2010 05:36 PM
Cold Running of Tj aeguy010 TJ Wrangler Technical Forum 2 01-19-2008 04:31 PM
My engine is running cold yamar18 TJ Wrangler Technical Forum 6 06-21-2007 05:19 PM
Engine running too cold Panteradon TJ Wrangler Technical Forum 3 02-20-2006 10:19 PM
