#1 | |
engine rebuild or swap?
So as stated in my previous post today, I have finally disassebled my 90" YJ and am ready to start spending some cash on the rebuild.
I have the AMC 258 I6 with 135K miles on it. My question is...Should I spend the money to rebuild it and add the fuel injection kit, or should I take that money and swap a different engine in it? If the swap is the way to go (which is how I am leaning), then what would you all recommend? Also what tranny to go with that? FYI: I am planning on the Ford 8.8 rear (unsure on the front axle), 4.5" RE SUA lift, 1" or 2" body lift, and 35 X 12.5" tires.
#2 |
I swapped an 05 4.0 into my 87 YJ. Dumped the BA10 and swapped inan AX15 and a newer NP231. You'll need some odds and ends but the parts can be located with a little digging.
I have a write up on www.itsajeep.org if you care to read it. Might shed some light. Just do a search in the forums for username jwicker. It was back in Jan/Feb 06. I'd definitely opt to swap for the multi port injected 4.0 !
~~~~~~~~~~~~~~~ Jon Evansville, Indiana 87 YJ/TJ Morph 3" (damned old) body lift, 1" Extended shackles, 1.5" Rough Country leaf springs, MP fuel injected 4.0, 3 row radiator, 33x12.5x15 ProComp X-Terrains, Eagle Alloy 8 Holes 15x10, Champion Winch, TJ Dash, 92 Roll Bar, AX15 5 speed, Posi-Lok, 1997 Dash and heater |
#3 |
The Mopar MPFI kit cost me $2000. You can probably swap to the 4.0 for way less. Get a used 4.0 and stroke it with your 4.2L crank. (Look into stroker motors). You should already have the AX15 tranny, I did with my 1990. I think the money for the MPFI kit was too high for the gain I got.
1990 Wrangler, 4.2L, 4.0 Head, Gibson Header, Mopar MPFI, ARB Snorkel, ProComp 4" lift, 33X12.5" AT, Superior Super 35 Axle w/ARB, Disk Brake conversion on rear. ARB in front D30, 8000lb Mile Marker winch, homemade rear bumper with swing away tire carrier. Extended flares. |
#4 |
http://www.ajeepthing.com/stroker-motor.html
You can easily get a junk 4.0 motor. WOuldn't cost a whole lot to get it machined and then all you need is the kit/parts from the link above. I love my stroker!
1995 YJ Stroked 4.5L I-6 Headders, high flow cat. and exhaust Big Bore Throttle Body, Cold Air intake Jet Chip Stage 2 plus thermostat 3 1/2 inch lift with 33x12.50 tires Posi Lock front diff and Ford 8.8 |
#5 |
i would either swap a 4.0 they have more power and would be worth it..or just put a 350 in there w/ a th350 trans or something like that
#6 |
T00L....
If you look into local rebuild shops, they can likely professionally rebuild your I6 for $2,200 to $2,500 to your specifications - also add $2,000 for the FI kit and install. The Joy of the I6 is that it's got a 3 bearing journal which makes it very reliable and limits vibration unlike V8's or I4's
My thought is that if you remanfacture the devil you know, you're much more likely to keep the synergy you may already have in all your pieces and parts together! The I6 is a great engine and one that you should not discard too readily ![]() |
#7 |
So I guess the way to go is to get a 4.0L and have it machined and add the stroker kit. I have the AX15 tranny, but want to go automatic. What tranny would be a good one for that setup?
I live in Maryland and the laws require a engine to be atleast 1990 or newer. So with that said, if I wanted to go with a 350 what would be the correct engine to look for? LS1? Thanks for all of the input. |
#8 | |
Its not a jeep if it dont have 4wd. |
#9 |
T00L....
Pushead - that's what I was quoted for the entire removal, remachine, reseal, grind, polish and paint the long block back to and above factory specs. These are guys in my area that I trust. That's what Machine Shop works goes for around the Seattle Area that I'm aware of.
#10 |
That is like I said if you let them pull and replace the motor. Ask them what it cost just to rebuild the shortblock. It will probably be around $800.
#11 |
Do a 4.0L swap. I got a 4.0L with 90K miles on it, flywheel, and wiring harness on ebay for $250.00
You can also reuse your existing AX-15 transmission. Just make sure you get the flywheel from the donor.
[B]Was a 4.2L inserted 4.0L from 93YJ, AX-15 Tranny, NP231 xfer case, 31x10.50 BFG All-Terrians, 3'BL, Rock-It Oil Pan Skid Plate, Smittybilt Double-Tube Front and Rear Bumpers, ordering RC 4' lift and 1'BL [/B] Just bought a 99XJ as my Daily Driver [COLOR="Red"] /|, '[___]' |---L -0||||0-[/COLOR] ()_) ()_) -o- )_) [URL="http://www.shawnmiller1975.com/jeep.htm"]http://www.shawnmiller1975.com/jeep.htm[/URL] |
#12 |
Thanks
Thanks for all of the great suggestions. I think that I will look for a used 4.0L and have it rebuilt with the stroker kit.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
