Engine Problems with Noise - JeepForum.com
post #1 of 3 Old 05-03-2007, 03:12 PM Thread Starter
arrow8807
My jeep started to make a thumping noise when it ran.....sounded like a knocking noise comeing from the front on the top near the valves....
i took off the valve cover and found that the number two cylinders intake rocker arm wasn't moving....no pressure is being apllied to the push rod....what could this be...is this the source of the knocking
i was thinking i have to pull out the camshaft and look at it....should i pull of the head to?
My uncle (a machanic) told me that a lifter arm of the camshaft might have collapsed but i can't find any referece to that in the service manual
any advice would be nice...
can you remove the camshaft through the timing chain
please list any thing else this noise could have been because it was hard to localize
also there was no metal shavings in the oil
thanks
arrow8807 is offline
post #2 of 3 Old 05-03-2007, 03:13 PM Thread Starter
arrow8807
i have a 1987 wrangler with a 4.2 6 cylinder 258 CID engine
stock carb
everything else is factory ....no major modifications
anything else you need just ask
post #3 of 3 Old 05-03-2007, 03:40 PM
nerf965
My 88 the lifter end grinded down and wore a grove in the lifter. I would say take the head off check over every thing.
nerf965 is offline
Congo cage noise problems stuckman TJ Wrangler Technical Forum 4 03-16-2009 12:39 PM
Engine noise and trans problems TopThrillJoe TJ Wrangler Technical Forum 0 10-29-2008 07:42 PM
more problems (noise) Sh4dowRac3r TJ Wrangler Technical Forum 3 08-22-2007 10:53 AM
post engine wash problems--engine light on.... PatriotCrawler TJ Wrangler Technical Forum 6 06-21-2007 01:10 AM
Engine Noise Problems Geaux555 TJ Wrangler Technical Forum 2 10-13-2003 09:25 PM
