Engine oil dipstick tube - JeepForum.com
post #1 of 12 Old 04-26-2013, 09:12 AM Thread Starter
bogleparsons
Does anyone by chance know if a TJ 2.5 dipstick tube will fit a YJ 2.5 ?
Dodge discontinued the part for my jeep.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #2 of 12 Old 04-26-2013, 10:41 AM
Siva283
Yes it should.
Ask me how I know...
Siva283 is offline
post #3 of 12 Old 04-26-2013, 06:11 PM
MukYJ
MukYJ's Avatar
The blocks are pretty much identical so it should fit.
~/Garth - 1993 Wrangler S 2.5
{ }|||||||{ } "MukYJ"
He's right, as soon as you remove the trackbar the fuel rail will arc on the battery, killing you and all the kittens in a ten mile radius.
MukYJ is offline
post #4 of 12 Old 04-29-2013, 06:43 AM Thread Starter
bogleparsons
Broke down and ordered one from Morris4x4 with shipping $50
what a dumb problem to have.
post #5 of 12 Old 04-29-2013, 10:23 AM
Que89YJ
If you are ever looking for small parts like that look a at car-parts.com or try http://www.cfoffroad.com/. He parts out Jeeps and especially YJ's
Que89YJ is offline
post #6 of 12 Old 04-29-2013, 11:15 AM Thread Starter
bogleparsons
Damn, thanks Que. I appreciate that.
post #7 of 12 Old 04-29-2013, 12:14 PM
Que89YJ
No problem. How did you break it?
Que89YJ is offline
post #8 of 12 Old 05-13-2013, 07:03 AM Thread Starter
bogleparsons
I broke it trying to force it in.
Once I got the new one I used the correct method of freezing the tube and heating the motor. It went in smoothly with the tap of a wrench on the flare.
Unfortunately I have a leak around the brand new oil dipstick tube.
So at this point I think I have cylinder blow bye....?
I will search for how to test that. I'm feeling bummed at this point.
post #9 of 12 Old 05-13-2013, 08:48 AM
Que89YJ
You dont get blow by leaks from the dip stick(Usually). It blows out the top. Check your CCV and the tubing on the vents on the valve cover. Make sure they are not blocked. Your tube issue might be just a bad seal and a little oil resistant rtv might fix ya up!
Que89YJ is offline
post #10 of 12 Old 05-13-2013, 09:17 AM
Jeepsr4me
Pull the tube and clean out the hole real good with some brake cleaner on a rag. Then when installing the tube back in put some RTV at the top 1 inch or so of the tube. When you seat it in, it will create a seal. I just did this yesterday.
And yes the dip stick is same for all 2.5s. I have a list of things that are the same and stuff that is not, based on years of the 2.5
Jeepsr4me is offline
post #11 of 12 Old 05-13-2013, 10:25 AM Thread Starter
bogleparsons
OK fella's thanks for the advice.
I'll first check the CCV/PVC lines.
Then if I have to bite my lip and pull that damn thing back out I will try and clean the hole and reinstall with RTV.
post #12 of 12 Old 05-13-2013, 11:10 AM
Que89YJ
Oil resistant stuff. Make sure you check both sides of the hoses on the valve cover.
Que89YJ is offline
