Engine noise after e-fan install... - JeepForum.com
post #1 of 12 Old 03-16-2010, 11:56 AM Thread Starter
Rhino70
Hey folks, got a problem after installing my e-fan. I am hearing a weird noise coming from the crankcase where the timing chain is. It vibrates the jeep a little but the noise is scary. Its like a low growl with a wobble. I am stumped on this one, anyone know what it could be?
Rhino70 is offline
post #2 of 12 Old 03-16-2010, 12:50 PM
88YJtoCJ
might be your harmonic balancer?
I also had a "sloppy" timing chain that rubbed the timing cover grinding some of the cover down... that can make a grumble.
Either way, if it sounds like grumbling or grinding, its usually not good!
88YJtoCJ is offline
post #3 of 12 Old 03-16-2010, 01:00 PM Thread Starter
Rhino70
I was hoping it wasn't the harmonic balancer...maybe taking the fan cluth off?? I don't want to have to put it back on.
Rhino70 is offline
post #4 of 12 Old 03-16-2010, 01:10 PM
idaholtby
Remove your belt and try turning all of the accessories to see if any may have a bad bearing. Other than that, I would suspect the timing chain/set.
idaholtby is offline
post #5 of 12 Old 03-16-2010, 01:12 PM Thread Starter
Rhino70
New alternator, tensioner, and just checked all other pulleys. Would it make sense that taking the load of the fan off would through it out of whack???
Rhino70 is offline
post #6 of 12 Old 03-16-2010, 01:16 PM
idaholtby
I can't see how it would. The noise may have been there before, the fan may have been masking the noise. I would still double check all of the accessories, especially the water pump. I've had to tie off the fan in the past just so I could track noises down.
post #7 of 12 Old 03-16-2010, 01:16 PM
ionakana
Grand Poobah
ionakana's Avatar
this may be a dumb question but did you have to use different bolts to connect the pulley back to the water pump after the fan was removed? If not could the orginal bolts be too long and it's letting the pulley move some? I don't know if that's a possibility, I'm just thinking out loud.
Psalm 14:1
Live in Georgia? click here-->
ionakana is offline
post #8 of 12 Old 03-16-2010, 01:22 PM
Flajeeper1
1987 YJ Wrangler
X2. You have to use shorter bolts. 1) If the bolts weren't threaded the full length they won't thread in enough to hold the pully securely. 2) If the bolts are too long they can hit the water pump housing.
Flajeeper1 is offline
post #9 of 12 Old 03-16-2010, 01:43 PM
jbolty
jbolty's Avatar
x3 on this. I bolted mine up and thankfully gave the waterpump a spin by hand and the bolts were hitting pretty bad.
If you need a balancer try here, damperdoctor.com. They had by far the best price, at least they did a year ago.
jbolty is offline
post #10 of 12 Old 03-16-2010, 04:45 PM Thread Starter
Rhino70
guys, i really appreciate your answers BUT this one is all on me. I put the belt back on the other day in a hurry and tightened it before it was in the correct position on the ps bracket. I just tightened it better and no sound! I feel like a big dummy but oh well, sometimes I get ahead of myself, just glad it isn't the chain or waterpump!!
Rhino70 is offline
post #11 of 12 Old 03-16-2010, 05:49 PM
Mark05059
so are we
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #12 of 12 Old 04-08-2010, 10:41 AM Thread Starter
Rhino70
Update on old post.
The noise came back this time with a squeak. Turns out it is the water pump, not to hard of a fix. The reason it was vibrating is I had recently removed the fan clutch to install a electric fan. The old water pump had been running for 15 years with the weight of the fan clutch on it then when it was removed the bearings started spinning different thus creating a racket. That created the problems. Now I have a new radiator and water pump installed and she is running like new! Thanks for all your help!
Rhino70 is offline
4H noise after install kdukes4 TJ Wrangler Technical Forum 12 01-01-2010 09:47 PM
Noise after B&M shifter install wildjeeper TJ Wrangler Technical Forum 2 12-24-2007 12:30 PM
noise after lift kit install YJames90 YJ Wrangler Technical Forum 4 10-03-2007 10:36 AM
Trans noise after shifter install 01locker TJ Wrangler Technical Forum 5 12-27-2006 09:33 PM
Whirring noise after BB install? BNovak TJ Wrangler Technical Forum 0 07-25-2004 07:51 PM
