Engine Mount frame patch suggestions? - JeepForum.com
post #1 of 5 Old 10-03-2013, 10:09 AM Thread Starter
HaskiE
HaskiE's Avatar
ok starting a new thread 'cause I need help on this - I think I have an idea, but please school me on how to do this right the first time!
Not sure what to call it; not the Engine Mount it's self, but the arm or tower or pylon thingy that goes under it... anyways, the guy who had this frame before me had a V8 in there, and his engine arms were home made C-channel; and he junked the jeep because of engine vibes... well, I found why he had engine vibes...
so I'm going to need to cut that section out and replace it. question is how...
This is what I'm thinking of doing: using 4x2x3/16 box tube from here:
http://www.ebay.com/itm/4-x-2-x-3-16...item4aca3b4556
I'll cut it down the middle making it a C-channel, with tails on the sides like this:
but would that be strong enough?
I was thinking about some sort of thru-the tube support, but I'm not sure how. Also this way doesn't give me anyway to plug weld it or add any extra beef... any ideas? maybe an internal fish plate? I can't really add too much to the outside because the engine arm/tower needs to mount to it...
thanks for you help guys,
Haskie
#theneverendingaxe
HaskiE is offline
post #2 of 5 Old 10-05-2013, 12:03 PM Thread Starter
HaskiE
HaskiE's Avatar
bump... ???
#theneverendingaxe
HaskiE is offline
post #3 of 5 Old 10-05-2013, 12:11 PM
johnny27030
I would put some support behind it, I might just get some 3/16? plate and slide it in there(on all sides). Plug weld it and maybe leave a 1/8 inch gap between the new piece and the frame rail that way you can weld to the inner plates, frame and replacement part all at once.
johnny27030 is offline
post #4 of 5 Old 10-06-2013, 08:20 AM Thread Starter
HaskiE
HaskiE's Avatar
that's a good idea, thanks! I was thinking some kind of internal plate but I couldn't figure out what would be best - I think that's the best route, I'll use the left over steel from the piece I ordered to kind of 'sleeve' the box tube from inside, over lapping all the welds on the C-channel piece with plug welds on either sides of each weld
just gotta wait for shipping now, ordered it on Friday.
#theneverendingaxe
HaskiE is offline
post #5 of 5 Old 11-11-2013, 05:02 PM Thread Starter
HaskiE
HaskiE's Avatar
finally got some damn time to work on this!
just flipped the frame over, and I'll do the upside down welds later this week hopefully. Feels much stronger than it was... especially when it had all the holes in it!
#theneverendingaxe
HaskiE is offline
