Engine modifications "more horsepower" - JeepForum.com
post #1 of 18 Old 09-04-2009, 11:47 AM Thread Starter
honda250ex
1987 YJ Wrangler
Hey I have a 1987 jeep wrangler with the 258ci 4.2 I6, I'm looking to getting some engine modifications. I don't know what to do I was wondering if you guys had any thoughts, feel free to put your input. I want something that's gonna give it more horse power.
Thanks
-MIKE
honda250ex is offline
post #2 of 18 Old 09-04-2009, 12:33 PM
4.7stroker
The best path to HP/TQ is to get a 4.0 and build a stroker, failing that installing a 4.0 head and an uprated cam is a good start.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 18 Old 09-04-2009, 12:52 PM
PASKS
Dwayne
stroker questions.....
what chamber size on the 4.2 head VS. the 4.0 head ?
what does the stroker kit make the final CI number ?
how much does it boost CR ?
is the cam you mention a custom grind or just a 4.0 cam ?
PASKS is offline
post #4 of 18 Old 09-04-2009, 12:55 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
if you want the keep your 4.2 then do some searches on doing a 4.0L HO head conversion and look into doing a fuel injection conversion. that will put at the power of doing a 4.0L stroker
To view the NEW
click here!!!
tobias94yj is offline
post #5 of 18 Old 09-04-2009, 02:29 PM
1998zj
Up the power much and that crappy BA10 transmission will bite the dust.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #6 of 18 Old 09-04-2009, 02:31 PM Thread Starter
honda250ex
1987 YJ Wrangler
yea Clifford performance makes a conversion for the 4.2 to the 4.0 motor same horse power and all that.
post #7 of 18 Old 09-04-2009, 03:09 PM
4.7stroker
I do not know the chamber size, the head flows much better making it a worthy swap.
The CR depends on the pistons used and weather you zero deck height the block/pistons.
The cam was from Comp cams for the 4.0.
Be sure to have the rotating assy spin balanced.
This may help http://www.jeepstrokers.com/forum/vi...a6ebbdac130ee8
Dwayne
[url]
[url]
post #8 of 18 Old 09-04-2009, 03:28 PM
Pitbullcustoms
What about porting and polishing the stock 4.2L head and a cam?
Pitbullcustoms is offline
post #9 of 18 Old 09-04-2009, 03:34 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
I would say not worth the money when 4.0 HO can be readily had. and I know I read on bc4x4 about the 4.0 stroker that when they researched the head work that the power gains were not significant.
To view the NEW
click here!!!
post #10 of 18 Old 09-04-2009, 04:03 PM
PASKS
This may help Jeep Strokers • Stroker Basics
Dwayne
thanks. that looks fun.
PASKS is offline
post #11 of 18 Old 09-04-2009, 04:46 PM
wheresthebfh
1987 YJ Wrangler
So I am doing the same thing. I was thinking stroker originally but as i got into the project more I settled on just doing the 4.0 swap. The main reason I settled with just the swap was the 4.0 was attainable and it was easy to find a good 4.0 with the ax-15 already mated. I do not know if cost is an issue but I just went ahead and bought an XJ and stole the 4.0/ax-15 and got a spare np231. The swap is moderately easy and I can use my 4.2 parts to build a stroker down the road. I also parted out the rest of the xj to offset the cost. Got the XJ for 700. This option also allows you to deal with the ba-10 issue. The wiring harness is a pain however but you will have to do it no matter what you do if you lose the 4.2
Milk it does a body good........
wheresthebfh is offline
post #12 of 18 Old 09-04-2009, 04:54 PM
vmann7
1987 YJ Wrangler
^^^X2, my 87 has borla headers, weber carb, hei dist and other little odds and ends, it still generates just enough power at speed to barely get out of its own way.
Don't be incremental like me, save and go with a 4.0/AX-15 already attached. Just my .02 pennies.
vmann7 is offline
post #13 of 18 Old 09-07-2009, 11:13 PM Thread Starter
honda250ex
1987 YJ Wrangler
Thanks for all you inputs, I appreciate it
post #14 of 18 Old 09-08-2009, 12:30 AM
lclark2074
lclark2074's Avatar
i thought a stroker was 4.2 crank in a 4.0 block making it 4.7 ?
night crew 226
lclark2074 is online now
post #15 of 18 Old 09-08-2009, 03:49 AM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
there are quite a few different combos but yes it usually is a 4.2 crank and connecting rods with 4.0 pistons which turn the 4.0 into a 4.5 due to the longer stroke. you can also use the 4.0 connecting rods but then you have to have custom pistons so that they do not slap the valves because 4.0 rods are longer than 4.2 rods
To view the NEW
click here!!!
2" Suspension Lift Modifications? mossimo19 TJ Wrangler Technical Forum 7 06-21-2013 11:54 AM
modifications i will have to make after putting in a 2.5" suspension lift wrangler10 TJ Wrangler Technical Forum 28 10-19-2009 07:11 PM
"Check Engine Light" and engine code P0442 MDC3 TJ Wrangler Technical Forum 3 08-05-2009 02:38 PM
Best "Donor" Vehicle for an engine/trans/txf case/axle swap??? alj9115 TJ Wrangler Technical Forum 0 08-05-2009 12:19 PM
03+ owners w/ auto and the O/D "vibe" or "engine lug" BIGNUTT TJ Wrangler Technical Forum 7 03-02-2007 02:40 PM
