engine marking - JeepForum.com
post #1 of 9 Old 05-09-2013, 10:15 PM Thread Starter
jeep16
engine marking
just grabbed up an engine jeep. identification says 403c13... can anybody decipher that for me please.
jeep16 is offline
post #2 of 9 Old 05-09-2013, 10:27 PM
Old4X
1990 CJ7
258 2 barrel built March 13, 1984
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 9 Old 05-09-2013, 10:49 PM Thread Starter
jeep16
will everything from my 1990 yj bolt up to it?
jeep16 is offline
post #4 of 9 Old 05-10-2013, 12:21 AM
JeepingJustin
Yes it should.
JeepingJustin is offline
post #5 of 9 Old 05-10-2013, 09:31 AM
Old4X
1990 CJ7
It depends on V- belts vs serpentine on your original engine.
I have a V belt 4.2, and everything I have would swap to the older motor.
Old4X is offline
post #6 of 9 Old 05-10-2013, 11:08 AM
dtn8tr
What about the difference in the early to mid 80s head bolts sizes?
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #7 of 9 Old 05-10-2013, 11:36 AM
Old4X
1990 CJ7
That is where it starts to get tricky. Also some valve covers will not swap over.
The head bolt size differences need researching if the OP is thinking of swapping heads.
I have long considered building a 258 using the old style fully counterweighted crankshaft. At almost 100 lbs stripped, it gives a very smooth idle and incredable low speed pulling without stalling.
But as to the original question, I thought external accessories were what was being swapped.
Old4X is offline
post #8 of 9 Old 05-11-2013, 01:03 PM Thread Starter
jeep16
yes external accessories. but i am also curious about this head thing now. will any 4.2 head work?
jeep16 is offline
post #9 of 9 Old 05-11-2013, 04:34 PM
Old4X
1990 CJ7
some 4.2's used 7/16" head bolts and some used 1/2" head bolts, just depends what year engine you have. Looks like 81-87 used 7/16" bolts and 71-80 and 88-90 used 1/2" head bolts.
You would have to use sleeves with the headbolts on that block if you went to a head made for 1/2" bolts.
Old4X is offline
