engine makes ticking sound - JeepForum.com
post #1 of 10 Old 04-18-2010, 03:29 PM Thread Starter
stevoYJ
i have a 4.0 liter engine and it has started to make a ticking sound when i first start driving it when the engines still cold...but when it warms up a bit it stops the ticking and sounds normal. im just wondering what is causing this and is my motor starting to show signs of giving out or what?
any help would be greatly appreciated
stevoYJ is offline
post #2 of 10 Old 04-18-2010, 03:53 PM
Rapid Fire
Ticking
Mine does the same thing. If I add 8 oz marvel mystery oil or even trans fluid in to the gas tank every time I fuel up the tic goes away. Sometimes I only put it in every other time. Mine is sticking valves. Others have reported bad lifters making the same sound. Easy way to tell which it is just put additive in the fuel, if it still makes the noise after one tank is used, it will most likely need new lifters.
Dale
Have you hugged your jeep today?
Rapid Fire is offline
post #3 of 10 Old 04-18-2010, 04:47 PM
MJMPC
Might be a cracked ehaust manifold.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 10 Old 04-18-2010, 09:11 PM
SoonerYJ
SoonerYJ's Avatar
2011 JK Wrangler
Mine started doing that and I ran half a can of seafoam in the tank and the other half in the crankcase for 2k miles and its nearly completely gone now. It started out sounding like marbles in a can.
___________
2011 Flame Red Rubicon (2-Door) with every option.
SoonerYJ is offline
post #5 of 10 Old 04-19-2010, 08:55 PM
schwebel
That's what mine sounded like. I kept swearing it was a valvetrain noise.
schwebel is offline
post #6 of 10 Old 04-20-2010, 02:46 AM
94yjsahara
your oil level ok?
94yjsahara is offline
post #7 of 10 Old 04-20-2010, 05:01 AM
jay-h
Originally Posted by stevoYJ View Post
...is my motor starting to show signs of giving out or what?
Probably just a lazy lifter. It can go for years like that, as long as it pumps up, you're fine.
jay-h is offline
post #8 of 10 Old 04-20-2010, 09:44 PM
seanhemp718
i changed my manifold (was cracked) and tune up kit from accel and no more noise. my 4.0 has 140,000 on it
seanhemp718 is offline
post #9 of 10 Old 04-20-2010, 09:49 PM
minnbowhunter
Sounds like a sticking lifter, I'd drive it.
minnbowhunter is offline
post #10 of 10 Old 04-27-2010, 05:59 PM Thread Starter
stevoYJ
yeah i put some oil additive in it and it stopped ticking for about 2 weeks but now its doing it again
stevoYJ is offline
engine help , ticking
4.0 makes dripping sound after engine turned off... JaredSS TJ Wrangler Technical Forum 8 06-18-2014 10:37 PM
engine makes ticking noise .. help!!!!! bdmsurf YJ Wrangler Technical Forum 16 04-12-2010 01:15 PM
Engine Ticking sound, Valves or Tapits? GreyfoxVt YJ Wrangler Technical Forum 8 09-22-2009 07:35 PM
Ticking Sound, even for a few sec w/ engine off YJ94cyl YJ Wrangler Technical Forum 7 06-08-2006 05:14 PM
Ticking sound from engine knick33 TJ Wrangler Technical Forum 8 04-15-2006 08:21 PM
