engine makes ticking noise .. help!!!!! - JeepForum.com
post #1 of 17 Old 04-10-2010, 07:20 PM Thread Starter
bdmsurf
I have a 95 yj 4cyl and its made a ticking noise but now it seems really loud when im accelerating. i can hear it on the highway. but when stoped at a light or just running you cant hear it. any idea what this is and how to fix it please let me know !!!!
bdmsurf is offline
post #2 of 17 Old 04-10-2010, 07:53 PM
Burnerman
Burnerman's Avatar
Cracked exhaust manifold or bad gasket? Is the CEL on? Has your mileage changed?
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 17 Old 04-10-2010, 09:47 PM
stevoYJ
im having the same problem on mine but my yj is a 4.0 and mine only seems to do it on occasion...but when it does do it i only hear it for the first couple of minutes i drive and then it goes away....anyone have any ideas about that one? its startn to worry me
stevoYJ is offline
post #4 of 17 Old 04-10-2010, 09:58 PM
Burnerman
Burnerman's Avatar
Could be a crack in the exhaust manifold. When cold the crack can open and cuase the ticking, onc e it heats up and expands it closes enough so you don't hear it. It could also be a lifter. I had a lifter tick in the 4.2 pretty bad. it took 5 mins to clear up. I ran some ATF in the oil just before an oil change to flush out any gunk in the lifters and did the oil change. I changed the oil again a few weeks later and the lifter tick was gone. That was 2yrs ago.Never came back...
96 ZJ.
post #5 of 17 Old 04-10-2010, 10:09 PM
bluebastard
im not sure about all the specifics in all honesty... but i have the same thing happen to my 97 tj with a 4.0... i let my dad(a mechanic of 20 years) look at it, and he said that its nothing to worry about.. the tick wasnt actually in the engine. there is this sensor on the right side of the engine that is kinda circular and you could hear it coming from that, and if you put your hand on it you could feel it pulsing every time there was a tick.. this could be it. anyways.. he said that there is absolutely nothing to worry about, it just gets noisy sometimes.
bluebastard is offline
post #6 of 17 Old 04-10-2010, 10:59 PM
moonshinefuel
A poorly tuned engine, or a component that needs replacement can make other things not work right and possibly lead to an unusual noise. Clogged fuel injector, bad fuel, all can attribute to strange noises. So, basically it is probably a good idea to first establish that your spark plugs, wires, rotor, cap, air filter, throttle body, fuel injectors, etc are all in good working order. poor plug wires can have a bad affect, some seem the think they last forever, they don't. Nor do coils, they last a long time, but do build up resistance eventually. Run some high quality fuel injector cleaner in you gas, and try to use better quality fuel such a mobil or chevron gas, gas such as am/pm gas is not a good thing imo. Ok, well, all of this may or may not pertain to the problem, but just make sure everything is in check here b4 you look elsewhere.
moonshinefuel is offline
post #7 of 17 Old 04-11-2010, 12:10 AM Thread Starter
bdmsurf
what is ATF ???
bdmsurf is offline
post #8 of 17 Old 04-11-2010, 12:20 AM
Mark455SD
1961 CJ5
Originally Posted by bdmsurf View Post
what is ATF ???
Automatic transmission fluid
Mark455SD is offline
post #9 of 17 Old 04-11-2010, 12:29 AM
Barrio
timing chain slapping around made mine sound like that.
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline
post #10 of 17 Old 04-11-2010, 12:35 AM
ryanmanuel
I have the whole "lifter-like tick" when I accelerate for the first 30 seconds of driving in my 4 banger after it has set for a while
ryanmanuel is offline
post #11 of 17 Old 04-11-2010, 12:44 AM
moonshinefuel
In my experience on my 4 cyl engine, I could not hear the timing chain slapping around on acceleration. It was only at low idle, then I could hear it.
post #12 of 17 Old 04-11-2010, 12:50 AM
moonshinefuel
I get the same thing as ryan does, been like that for several years.
post #13 of 17 Old 04-11-2010, 06:27 AM
Burnerman
Burnerman's Avatar
Your TJ has a bunch of emissions stuff for the ODBII. That heartbeat you hear is a valve in the evap system. YJ's don't have them.
96 ZJ.
post #14 of 17 Old 04-11-2010, 08:40 AM Thread Starter
bdmsurf
so should i add a little moer oil to make the noise go down , i dont think its a cracked manifold like u said lifter might be that.
bdmsurf is offline
post #15 of 17 Old 04-12-2010, 02:01 AM
94yjsahara
I also get this ticking noise, increases in tempo when I hit the gas, slows when I let off. Difference is from yours is that the ticking only happens after the car is fully warmed up! wtf!
94yjsahara is offline
Engine ticking noise???? haulincats TJ Wrangler Technical Forum 8 04-12-2010 02:04 AM
07 engine ticking noise alhuber JK Wrangler Technical Forum 3 09-29-2009 08:58 PM
ticking noise from engine reelfaith TJ Wrangler Technical Forum 26 05-07-2009 11:09 AM
Ticking noise from engine DBLJ TJ Wrangler Technical Forum 4 11-22-2008 08:25 AM
Ticking noise from engine Mr. Tarmac TJ Wrangler Technical Forum 26 12-03-2005 05:06 PM
