Engine Loses Power on the Highway, Help? - JeepForum.com
post #1 of 9 Old 08-22-2011, 11:01 AM Thread Starter
dan-E
Hey guys,
I have a '95 with the 2.5L engine that has around 101,000 miles. I was on the freeway doing about 65 when all of a sudden the engine started misfiring/lugging/surging? Not sure what to call it, exactly. Basically, it feels like the engine sputters like it is low on gas and running on fumes, so it slows down briefly before it catches again, but never completely stalls. (I had half a tank left.) I limped home by downshifting and keeping the rpms up but once I got off the freeway and drove the streets, it ran fine.
I drove it to the shop the next day (no highway) but again, the engine ran fine and I couldn't get it check out since the were close. About a week later, after no issues I ran into the same problem on almost the same stretch of freeway, except this time my tank was nearly full.
It's weird how it's fine around town but this occurred twice at 60-65. My first thought was maybe the fuel filter but I just bought this I'm no mechanic so any advice would be appriciated. Thanks in advance.
dan-E is offline
post #2 of 9 Old 08-22-2011, 11:08 AM
chazharris97tj
Any dash lights come on? Check the throttle position sensor. I had the same problem happen to me but I had a light come on so I had it checked. Still haven't replaced it tho. Happens like twice a month for me.
chazharris97tj is offline
post #3 of 9 Old 08-22-2011, 11:54 AM
Que89YJ
Hey Dan-E there are a few possibilities the first place to start is by checking your fault codes. You can do it by cycling the key 3 times. Post back what you find. It could be crank shaft position sensor or a fuel issue.
http://www.jeepforum.com/wiki/index....k_Engine_Codes
Que89YJ is offline
post #4 of 9 Old 08-22-2011, 01:55 PM Thread Starter
dan-E
[QUOTE=Que89YJ;12060605]Hey Dan-E there are a few possibilities the first place to start is by checking your fault codes. You can do it by cycling the key 3 times. Post back what you find. It could be crank shaft position sensor or a fuel issue. /QUOTE]
I took your suggestion and I got the codes 12, 21, and 55. The only thing that would concern me is 21, which means either the oxygen is off the or the O2 sensor is broken, but I'm not sure how that would make the engine feel like it's suffering from fuel starvation.
dan-E is offline
post #5 of 9 Old 08-22-2011, 02:01 PM
oldtime_ironman
A bad O2 sensor reading could easily do that - its the main component that determines fuel delivery on these.
oldtime_ironman is offline
post #6 of 9 Old 08-22-2011, 02:07 PM
Que89YJ
it could mean a few different things. Hey bad 02 sensor, cracked exhaust manifold, or a loss of fuel pressure. I would start by renting a fuel gauge. Hook it up to the fuel rail and see if your fuel pressure stays at a constant 31 to 39 p s i
Que89YJ is offline
post #7 of 9 Old 08-22-2011, 03:30 PM
oldtime_ironman
^^^ X2 what Que says. There are a few things that can cause a bad O2 sensor reading even if the sensor is OK. Fuel pressure is important so like he says get a gauge and check it first.
post #8 of 9 Old 08-22-2011, 10:22 PM Thread Starter
dan-E
Thanks for all the help!
dan-E is offline
post #9 of 9 Old 08-24-2011, 01:50 PM
ronniez
i am having a similar problem and replaced the plugs/wires/cap/rotor/02/map next on the list is the crank sensor and testing the fuel pressure and fuel filter. my crank sensor was replaced 5 years ago when i bought the jeep but its only 20 bucks so whatever will get a new one..... sure it cant hurt. AS far as the fuel pressure i need to head over to autozone and pick one up. Do i need to get an adapter for it to fit my size schrader valve?
ronniez is offline
2.4L Will Not Idle & Engine Loses Power DeepSky TJ Wrangler Technical Forum 4 02-21-2011 07:25 AM
Engine loses power 93YJ4me YJ Wrangler Technical Forum 1 02-18-2010 07:54 PM
No Engine Power On Highway jubilee YJ Wrangler Technical Forum 23 01-25-2010 10:12 AM
1997 Wrangler Engine Loses Power, then comes back on, while driving. crbaum2 TJ Wrangler Technical Forum 4 10-11-2008 10:47 AM
Engine Malfunction Light came on & Stays On - Rubi Loses Power YoungTurk JK Wrangler Technical Forum 10 03-25-2007 05:21 PM
