Engine leaking gasoline quickly.4.2L - JeepForum.com
post #1 of 10 Old 05-17-2010, 02:14 PM Thread Starter
yjyjyj1
My 88 yj has been fine for the last few months, but recently there has been a strong smell of gasoline after I drive it. Today i finally popped the hood with the engine running to see gasoline flowing freely from undernead the air filter assembly and intake (I think, Im 16 so bear with me)
i have a picture and the pink circle represents where underneath the black intake thing it seems to be originating. The green is where it leaks too.
yjyjyj1 is offline
post #2 of 10 Old 05-17-2010, 02:23 PM
ImpactFabWorks
That's right where the lines exit the fuel filter so I would start there. are you sure it's coming from the intake?
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #3 of 10 Old 05-17-2010, 08:00 PM Thread Starter
yjyjyj1
It appears to come from some tube or rod under and between those two silver caps
yjyjyj1 is offline
post #4 of 10 Old 05-17-2010, 08:08 PM
Burnerman
Burnerman's Avatar
Take the air cleaner off and take a look. It could be as simple as a cracked fuel hose between the filter and carb inlet. DON"T run it with that fuel leak. The exhaust manifold is directly below that leak and you could have a fire.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #5 of 10 Old 05-17-2010, 08:21 PM
spawnofsatan
look like your return line is crack
spawnofsatan is offline
post #6 of 10 Old 05-17-2010, 08:35 PM
zrides
Take off the air cleaner and see exactly where it is leaking from, provide updated photo if possible. Make sure you have a fire extinquisher close, if it is running down the air cleaner, then you remove it, it just might leak on top of the exhaust and could get scary, just dont let it keep running for long. Fuel leaks are serious and could become a huge problem fast, figure it out before you drive it anymore.
zrides is offline
post #7 of 10 Old 05-17-2010, 08:45 PM Thread Starter
yjyjyj1
Probably isn't good I just checked this out. Ill open er up tomorrow
yjyjyj1 is offline
post #8 of 10 Old 05-17-2010, 09:37 PM
88blkyj
Most likely the lines rotted away. Had a mess with it on mine a few weeks ago.
88blkyj is offline
post #9 of 10 Old 05-20-2010, 07:37 PM Thread Starter
yjyjyj1
figured it out.just readjusted the hose and tightened the tie
yjyjyj1 is offline
post #10 of 10 Old 05-20-2010, 07:42 PM
dtn8tr
Tie? I hope you're not using a zip tie. It's great for an emergency fix but you really need to have a hose clamp on there.
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
Engine leaking ussue?? (Pics) jeep_maniack YJ Wrangler Technical Forum 18 04-11-2010 11:29 AM
leaking engine coolant from crank 4.0 stevensinger TJ Wrangler Technical Forum 7 06-29-2009 08:36 PM
leaking under engine, dont know what? Columbia TJ TJ Wrangler Technical Forum 5 07-03-2008 11:58 AM
Oil Leaking From Front of Engine Tshark299 YJ Wrangler Technical Forum 4 04-26-2006 11:21 AM
Leaking from front of engine BRad704 YJ Wrangler Technical Forum 5 08-25-2005 07:09 AM
