Engine knocking/clanking when accelerating hard, and excessive blowby in air filter? - JeepForum.com
post #1 of 3 Old 03-04-2013, 09:38 AM Thread Starter
sethisimmons
Just got my 1988 YJ w/ 4.2l manual back in July of last year, and am working on starting to get it trail ready. Ever since I've gotten it I've had two issues though.
First: When accelerating hard/going up hills, there is a clanking noise and I don't seem to have much power. It doesn't sound like any piston knocking noise I've heard before, more like a loose bolt vibrating or something. I've checked all the bolts I can think of, and everything looks nice and tight, but the noise persists. It's quite noticeable when I'm on the highway, and is very annoying. I mainly just wanna see if it's something that could be evidence of a deeper issue with the engine/transmission.
Second: Ever since I got the Jeep I've been slowly noticing a blowby issue where oil is getting blown back into the air filter. It got so bad once that I practically lost all my oil into the air filter pan and ruined the filter. Ever since then I still seem to have some blowby coming back into that pan, nothing as bad, but still definitely there. Any ideas on what I can do to fix that?
Thanks for reading and in advance for any help! I've been on the forum for a while but it's my first post. Excited to get involved in the Jeep community!
sethisimmons is offline
post #2 of 3 Old 03-04-2013, 12:02 PM
Que89YJ
Bad pcv on the blowby. Pull your valve cover. Chances are the inside is mucked up too.Other possibility is compression issue with bad rings. Run the compression test.
Que89YJ is offline
post #3 of 3 Old 03-04-2013, 01:01 PM Thread Starter
sethisimmons
Would that be the front PCV, or the rear breather? I replaced the front PCV to be sure about a month ago, and it seems to have helped a little bit, but I am definitely still getting more than I should. I'll do a compression test when I get off work, and probably pick up a new breather hose as well to ensure its not cracked/leaking. Thanks! I'll update after I do the test. Also gonna pick up a valve cover gasket to replace that, just to be sure. Thanks again for the help!
