engine to interior harness on firewall...diagrams needed...HELP ! - JeepForum.com
post #1 of 4 Old 01-20-2012, 08:41 PM Thread Starter
Keepajeep
I am in need of wiring diagrams for the following connection ( 10 pin )
connection from the interior on the firewall to the engine harness
( the one through the big boot !)
1994 YJ 2.5L interior
1991 YJ 4.0L engine
trying to get my 4.0L swap running..
thx
Jake Bondy,Sarnia, ON Canada
Build it, Break it, Fix it, Replace it, REPEAT !!!!!!!!!!!! Jeep......A way of life
Keepajeep is offline
post #2 of 4 Old 01-20-2012, 09:50 PM
jdubsjeep
jdubsjeep is offline
post #3 of 4 Old 01-20-2012, 10:10 PM
brentd711
Not sure if this is what you need but here it is anyway
1 DB/YL AC CLUTCH
2 DB FUEL GAUGE
3 VT/YL COOLANT TEMP
4 RD IGNITION
5 BK/RD HORN
6 LB AC REQUEST
7 YL CRANK RELAY
8 GY/YL OIL PRESSURE
9 VT BACKUP SWITCH
10 DG/GY 4WD SWITCH
brentd711 is offline
post #4 of 4 Old 01-21-2012, 06:23 AM Thread Starter
Keepajeep
thanks, saves a lot of hassle
vacuum issues diagrams needed HEDLOCUST YJ Wrangler Technical Forum 5 11-28-2011 10:04 PM
needed diagrams bigboss408 YJ Wrangler Technical Forum 5 12-25-2009 08:23 PM
Relay harness underhood by firewall? Neo1130 YJ Wrangler Technical Forum 5 06-30-2009 12:44 PM
Two wires on main harness on firewall: what's it for? rwmorrisonjr YJ Wrangler Technical Forum 1 04-27-2007 10:08 PM
TPI into Jeep firewall wiring harness Qdanj YJ Wrangler Technical Forum 0 02-28-2006 01:27 PM
