Engine idles at 3k - JeepForum.com
post #1 of 8 Old 02-13-2012, 06:58 PM Thread Starter
94chb
Engine idles at 3k
hey guys, my buddy has a 95 wrangler 2.5 the jeep ran great but the water pump was bad so i replaced it for him now when you crank the jeep it stays at 3k and wont idle down. ive looked for vacuum leaks and didnt find anything. idk what the hell the problem is . maybe you can help.
94chb is offline
post #2 of 8 Old 02-13-2012, 07:03 PM
dilligaf69
Make sure that you didn't by some chance move the throttle cable, check to make sure the butterfly on the throttle body is closed. I know you didn't have to mess with it while changing the water pump, but there is always that chance.
Dent, what dent.... That's not a dent.... that's a good memory.
dilligaf69 is offline
post #3 of 8 Old 02-13-2012, 07:04 PM Thread Starter
94chb
i checked i also choked it with my hand and it still didnt idle down.
94chb is offline
post #4 of 8 Old 02-13-2012, 07:30 PM
pasinbuy
First try cleaning the IAC it is on the pass side of the throttle body. If that does not work, go buy a new one.
pasinbuy is offline
post #5 of 8 Old 02-13-2012, 07:31 PM
dilligaf69
double check all of you manifold vacuum lines to make sure they didn't get cracked. only other reason I can think of is for some reason the idle speed control motor has gotten stuck open or has gotten disconnected. That shouldn't have been affected by changing the water pump though.
post #6 of 8 Old 02-13-2012, 07:34 PM Thread Starter
94chb
but even with me sticking hand hand over the TB and choking it should have idled it down. ive checked and checked and checked. ill wait til tmw to look again. im stumped.
94chb is offline
post #7 of 8 Old 02-18-2012, 08:30 PM Thread Starter
94chb
Fixed the Problem. Bad intake manifold gasket. replaced it and everythign is perfect.
94chb is offline
post #8 of 8 Old 02-21-2012, 08:00 PM
dilligaf69
good to hear you got it fixed. That would have been my next guess if it wasn't the IAC.
95 yj idles rough after right engine bracket broke ! IvansRed95YJ YJ Wrangler Technical Forum 7 10-29-2011 11:57 AM
90 YJ idles at 3k-3.5k! lexinator02 YJ Wrangler Technical Forum 6 04-07-2010 12:53 PM
Rough/low idle once engine warms up...idles fine when cold sb127 TJ Wrangler Technical Forum 14 11-14-2008 11:06 AM
4.0 idles rough.. have 6 engine codes.. mikevsgeek TJ Wrangler Technical Forum 1 09-17-2007 05:27 PM
Idles at 3k? bmcwbc TJ Wrangler Technical Forum 9 05-26-2006 11:24 AM
