Engine harness plug - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Engine harness plug
New rockridge 4wd sales rep!!!FS: Wranger BRIGHT License Plate LED! Just $3! Great valueTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 05-25-2014, 06:36 PM   #1
nis240rb
Engine harness plug
Hi everyone new on the forum so please for give the newbie ness. I have a 89 yj that im putting a 4.0 Ho from a 93 grand Cherokee with a 96 aw4 and np231. I swapped the dash harness and engine harness with one from a 92 yj 4.0. my question is there is a 10 pin plug on the engine harness near the under hood fuse box that i cant figure out what its for.
nis240rb is offline   Reply With Quote Quick reply to this message
Unread 05-25-2014, 06:59 PM   #2
nis240rb
http://www.jeepforum.com/forum/attac...1&d=1401065964
Unread 05-26-2014, 07:12 AM   #3
nis240rb
I have more pics if needed. Thanks in advance for any help.
Unread 05-26-2014, 05:58 PM   #4
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
That plug might be for daytime running lights (DRL) module. Ignore it until it might be important!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
If what doesn't kill you, makes you stronger, I should be able to bench press a Grand Cherokee by now!
laybackman is offline   Reply With Quote Quick reply to this message
Unread 05-26-2014, 07:56 PM   #5
nis240rb
Update I pulled the harness and traced some wires looks like the vss vehicle speed sensor wires run in this plug but not sure what else. Its like im missing a sub harness. Any one have any ideas.
Unread 05-26-2014, 08:08 PM   #6
laybackman
laybackman's Avatar
2010 JK Wrangler
Ok just checkd and that plug is definitely the DRL module plug.
And some of those wires are common with the VSS sensor on the automatic tranny, which in turn tie into the tranny control module which is usually mounted under the dash. And the auto tranny has a sub harness
Unread 05-26-2014, 09:07 PM   #7
nis240rb
Thanks but everything I can find on the drl module says its located on the drivers side up near the head light this plug is way to close to the under hood fuse box for that. Does anyone know where the vss wires run after the leave the sensor?
Unread 05-27-2014, 06:15 AM   #8
laybackman
laybackman's Avatar
2010 JK Wrangler
The DRL uses the signal from the VSS to put the headlamps on at 50% power.
On an XJ harness it looks like the DRL module is where your plug is located.....let me do some more digging...
Unread 05-27-2014, 06:24 AM   #9
laybackman
laybackman's Avatar
2010 JK Wrangler
Ok That plug is not for your DRL. that plug should be located near the left front headlight near/under the intake air box. More checking...
Unread 05-27-2014, 07:13 AM   #10
laybackman
laybackman's Avatar
2010 JK Wrangler
I just looked at my '95YJ harness. It does not have that plug like your harness does.
BUT, the '95 Grand Cherokee harness has the DRL plug in that area.
That plug has some wires that are common with the VSS plug for the auto tranny, right? That could just be a ground which they share.
Post the other pictures you have and how about you list the wire colors/pin numbers if they are on the plug.
I would work around that plug in the meantime.
Unread 05-27-2014, 12:21 PM   #11
nis240rb
Thanks for the help. this is the wire colors and where i traced them too ill get more pis up when i get home this after noon.
orange/black=fuel pump relay
black/yellow=ground
green/black=runs to the plug that runs into jeep under center of dash
black=pin 11 at ecu plug (power ground)
black/white=engine starter relay
white/black=ac relay
other white/black=pin 7 on ecu (volt supply 8 or 5)
black/red=pin 4 ecu(sensor ground)
light brown=runs to the plug that runs into jeep under center of dash
blue=ecu pin 47 (vss)
Unread 05-27-2014, 02:27 PM   #12
laybackman
laybackman's Avatar
2010 JK Wrangler
black/yellow=ground
Everything I see says that is the plug for the auto tranny. I also believe that there is a sub harness that plugs into that plug to connect it to the tranny control module.
Unread 05-27-2014, 02:36 PM   #13
laybackman
laybackman's Avatar
2010 JK Wrangler
How far along are you with this build? I would ignore that plug until it becomes a freakin' problem!!!!!
Unread 05-27-2014, 05:27 PM   #14
nis240rb
Im at the point that I need to wire in the aw4 tranny. I thought the tf999 auto in a yj was not computer controlled. Remember the harness is from a 93 yj.
Unread 05-27-2014, 06:27 PM   #15
laybackman
laybackman's Avatar
2010 JK Wrangler
For the 3 speed automatic tranny I think you are right the TCC solenoid is controlled by the brain. That has one wire going from the TCC solenoid screwed into the tranny to the TCC solenoid relay located on the right side of the dash panel next to the battery.
Then I think there is a TV cable that goes to the throttle linkage. And then you need a NSS sensor. The Neutral Start Sensor gives you ground for the ASD relay and when you shift into reverse allows the reverse light to go on.
BUT I think the AW4 has its own brain usually located under the dash behind the glove box??? And the year of the brain has to be compatible with the year of the tranny because 'things' often changed.
Google search got me this;
http://www.jeepforum.com/forum/f19/a...tions-1475816/
http://www.naxja.org/forum/showthread.php?t=1053970
