Engine dies when headlights are on - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Engine dies when headlights are on
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy Aluminum BumpersThe RuffStuff "I can't go to EJS" Sale!
Unread 01-27-2014, 09:32 AM   #1
CKjeeps
1987 J-Series Truck
I have a 89 YJ that when I turn the head lights on the engine starts to stumble and die. I have rewired all headlight wires from the firewall bulkhead to the headlights, nothing inside the cab yet. It had had to have many grounds replaced as the PO did a horrible job at fixing grounding issues. I can drive it fine without headlights. the turn signals and brakes work fine as do the dash lights. Could this be a bad switch? something else?
Check out my build. 95 wrangler 5.3 vortec, 14 bolt, 10 bolt, sm465, np205, 4 link rear, link front.
http://www.jeepforum.com/forum/f22/project-betty-white-1464639/
CKjeeps is offline   Reply With Quote
Unread 01-27-2014, 10:58 AM   #2
scraper
It could be a failing alternator. It's not putting out enough power, and when the lights come on they hog up everything the struggling alternator is producing. Just a guess though, you can take it to an auto store to have it tested for free.
scraper is offline   Reply With Quote
Unread 01-27-2014, 11:07 AM   #3
Michaelgoesrawr
Michaelgoesrawr's Avatar
I doubt it's solely the alternator. You can drive your jeep for at least a half an hour on the battery alone. I'd go with a bad ground. Or a mixed ground causing interference.
Help our dog Bo! https://fundly.com/give-bo-a-chance
Michaelgoesrawr is offline   Reply With Quote
Unread 01-27-2014, 11:23 AM   #4
Que89YJ
No way is it an alternator issue unless you see the voltage noise dive when you turn on the headlights. What does the voltage guage say with them on/off?
Que89YJ is offline   Reply With Quote
Unread 01-27-2014, 12:04 PM   #5
Peety
I know that this sounds stoopid, but, mine did the same thing, it was the O2 sensor. Unplug it.
Peety is offline   Reply With Quote
Unread 01-27-2014, 07:19 PM   #6
laybackman
Bikini Bridge Inspector
laybackman's Avatar
Check the grounds by the headlights....
EDIT: Check the ground from the firewall to the dipstick bracket also....
"Once good behavior becomes the exception and not the rule your society has begun to fail…..we are there." laybackman
If your girl is throwing gang signs with her toes you're hitting the spot.
"If we cannot afford to take care of Veterans, then we should stop making them."
David C. Wilker Jr. USAF (RET)
laybackman is offline   Reply With Quote
Unread 01-27-2014, 07:45 PM   #7
Que89YJ
Good call.
Unread 01-27-2014, 07:54 PM   #8
laybackman
laybackman's Avatar
Originally Posted by Que89YJ View Post
Good call.
Even a blind squirrel can find a nut once in a while......
Not that I'm necessarily right mind you!
Unread 01-27-2014, 08:16 PM   #9
Que89YJ
Your not necessarily wrong either!
Unread 01-28-2014, 04:54 AM   #10
Mark05059
you cant be ALL right... you gotta be half left
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote
Unread 01-28-2014, 05:35 AM   #11
laybackman
laybackman's Avatar
Even if I were a blind squirrel!
Unread 01-28-2014, 04:28 PM   #12
halmc
If everyone were right, no one would be left.
Evidence is the Kryptonite of the Pious
halmc is offline   Reply With Quote
Unread 01-28-2014, 05:36 PM   #13
laybackman
laybackman's Avatar
