Engine Diagnostic Code - JeepForum.com
post #1 of 5 Old 01-23-2001, 05:18 PM Thread Starter
93YJ
I am currently working on a friends '91 YJ that he sank in the river last weekend. I have changed all of the fluids including the fuel, replaced spark plugs, wires, filters, inspected distributer inside and out. The symptoms are running rough and won't idle when warm. The check engine light gives me the diagnostic code 24 which is "Throttle position circuit out of range".
Does this code mean anything to anyone, or has anyone troubleshot this type problem before? I really don't even know what a throttle position circuit is so any help at all would be appreciated.
93YJ is offline
post #2 of 5 Old 02-02-2001, 10:00 AM
jeeptuff
Sound like the water could have damaged the TPS(Throttle Position Sensor) either the voltage is too high or too low, does it have the 4 or 6 cylinder? The testin is a bit different for the two, and so are locations.
Eric
1993 Wrangler 4.0L
Eric
Once again Jeepless in Seattle
jeeptuff is offline
post #3 of 5 Old 02-02-2001, 10:04 AM Thread Starter
93YJ
Thanks for the reply. I found out that this TPS sensor was the problem. Swapped it out, and it runs like a champ. Thanks again!
93YJ is offline
post #4 of 5 Old 02-04-2001, 05:06 AM
jeeptuff
Glad to see it is up and running another great machine is back on the road and off.
Eric
1993 Wrangler 4.0L
Eric
jeeptuff is offline
post #5 of 5 Old 11-16-2008, 02:10 PM
nfrank44
Congrats. Maybe Your Friend Will Think Twice Before Trying To Make His Jeep Into A Submarine.
.:Frank-You:.
94 YJ 2.5L
97 TJ 2.5L
nfrank44 is offline
Diagnostic Code 21... mall0y TJ Wrangler Technical Forum 9 10-11-2007 05:56 PM
Diagnostic code 25??? Falco YJ Wrangler Technical Forum 4 08-17-2006 08:05 PM
Diagnostic code 27 gwiley YJ Wrangler Technical Forum 2 06-05-2006 09:41 AM
diagnostic code help rsoffar YJ Wrangler Technical Forum 1 08-22-2005 01:22 PM
Diagnostic code 33 (w/o AC?!?)` rwfisheriv YJ Wrangler Technical Forum 1 07-23-2002 01:36 AM
