Engine cutting out - JeepForum.com
post #1 of 4 Old 03-31-2007, 12:39 PM Thread Starter
rtingley
Junior Member
Engine cutting out
Hey, my 4.0l bucks and jumps and the engine cuts out momentarily when I go over bumps in the road. Anyone have any thoughts?
rtingley is offline
post #2 of 4 Old 03-31-2007, 01:11 PM
trickle26
trickle26's Avatar
make sure your plug wires are on tight (both ends) and your dist. cap isn't a little loose. Check your battery cables as well. Did you try to pull the codes with the key-on off method?? Time for a tune-up maybe?
97' ZJ Limited V8 - 5.2 liter
94' YJ 4.0 ho -SE -
past jeeps: 89' YJ
87' YJ Laredo
88' YJ Sahara
90' XJ Limited
trickle26 is offline
post #3 of 4 Old 03-31-2007, 01:28 PM Thread Starter
rtingley
Junior Member
Didn't do the code thing with the key. I also noticed that when i am at idol for a period of time it the rpm's go up and down.I think it is a vaccuum problem because I had to rig my ccv to the manifold the ruber gromet fell apart and I broke a piece off the small tube that connects it to the manifold. I also think maybe the tubing I am using is to thin and collapses a little and resticts the airflow.
rtingley is offline
post #4 of 4 Old 03-31-2007, 01:42 PM
trickle26
trickle26's Avatar
Check your TPS sensor as well (connects to throttle body). Or maybe IAC (idle air control valve)
I had a rough idle as well as misfire and the TPS corrected the problem.
94' YJ 4.0 ho -SE -
past jeeps: 89' YJ
87' YJ Laredo
88' YJ Sahara
90' XJ Limited
Engine cutting out bhowe YJ Wrangler Technical Forum 4 11-10-2011 06:53 AM
4.0L Engine cutting out around 2,000 RPM Dust4Life TJ Wrangler Technical Forum 5 12-29-2008 06:41 PM
Engine cutting out........HELP JIMMYJONES TJ Wrangler Technical Forum 5 07-17-2006 04:58 PM
Need Help Engine cutting out meador36 YJ Wrangler Technical Forum 6 11-10-2004 08:07 PM
engine cutting out mitchj01 YJ Wrangler Technical Forum 13 05-14-2004 10:23 AM
