#1 | |
Engine cuts out at speed
My 89 4.2L started cutting out while running. It just dies...no sputtering or warning. Sometimes it kicks back in all by itself and sometimes I have to pull over and re-start it...(bigtime backfire when it kicks in by itself!!!)
I did the Nutter bypass a while back and it was running fine for months after that. I put changed the Distributor car and rotor and it still does it. Could it be the coil ?? Any help would be much appreciated.
Chip 2000 TJ...Almost stock Quick Discos and MT/R's. |
#2 |
Mine did the same thing. It turned out to be the ECU.
89 yj w/ mopar mpi and 4.0 head.94 ax-15 tranny and t-case, more mods comin. |
#3 |
I've had a recent problem just like that--about 4 times over the past month, it would just instantly die at around 45 mph--no sputtering or anything, even though it was just idling perfectly and cranks right back up, even while I'm still coasting. I don't know if the problem is solved, but I put a new ignition module on it last weekend and haven't had a single problem in 5 days now (knock on wood). I figured 150k on the original module was enough. Aggravating thing is that the module on the CJ is $17 from Advance, whereas the one for the YJ (the problem one) was $55 (both for the exact same engine and look identical). But, it has a lifetime warranty, so I'll yank it again if it gives me trouble.
I've been talking to Bob K on here about it because he had some similar problems, but his turned out to be the ignition switch. I'd like someone who knows to let us know if a failing coil is an "all or nothing" kind of thing because if mine does it again, I'm going to have to turn to the coil, the pickup in the distributor, or possibly the ignition switch.
'85 CJ-7, '90 Sahara, '01 Sahara.....a proud Jeep owner since '97 |
#4 | |
JF Administrator, eh?
Re: Engine cuts out at speed
Hello, my name is Vance and I am a Jeepaholic. Its better to be naked with your friends, than to be clothed with your enemies #1 From street to trail, '88 YJ on 38" tires does it all well #2 Silver 2006 TJ Unlimited, zombie ready as the daily-driver .. and now a Kawasaki KLR650 DualSport bike TEOTWAWKI |
#5 |
Pimp Hand
i had a similar problem as well.. turned out to be a hair line crack in the distributer cap.
___________________________________________ What is all of this talk of Savvily designed products?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
