Engine Control Unit (ECU) - JeepForum.com
post #1 of 8 Old 05-19-2010, 03:35 PM Thread Starter
reckfield
Where is the ECU located on a 90 Wrangler 2.5L? How difficult is it to remove? Is this something that Autozone or another parts store can test? Thanks for your help.
reckfield is offline
post #2 of 8 Old 05-19-2010, 04:53 PM
Mark05059
it is located behind the glove compartment. Not too hard to remove. A few screws and I believe 4 nuts for the grab handle. I dont know for sure if autozone or another parts store can test.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 8 Old 05-20-2010, 06:20 AM
Que89YJ
Whats going on? Whats the problem?
Que89YJ is offline
post #4 of 8 Old 05-20-2010, 09:50 AM
Que89YJ
When I first got the Jeep, I had problems with it idling correctly. It had sat for awhile. I first replaced plugs, wires, distributor cap, rotor and coil. Still had problems. Then I replaced the idle air control valve and helped alot. When I would shut off the engine, the IAC would then open the throttle body. So, when starting it would act normally, stating at about 2 grand and then falling down to just below 1000. Now, it does not do that anymore, except occasionally. I have no idea why. Thus, I am guessing the problem could be in the ignition control module or the ECU. I can have the ICM tested at Autozone. If that is okay, then I'm guessing the issue is the ECU. It starts up and runs okay besides the issue mentioned above with the IAC. But, somedays it will idle way down at 500 and die and other days it will idle at about 800 but will fall down to 500 or less and then pick backup to 800 or so about three times, then be fine. Strange
Ok, this is the post you sent. When you replaced the Iac did you also clean the the throttle body and IAC passages? High idle is usually an indication of a vacuum leak. Check for vacuum leaks and remember that you have vauum lines running to your axle and you heater controller in the insrument panel.
Que89YJ is offline
post #5 of 8 Old 05-20-2010, 11:52 AM
Que89YJ
I think you need to get a meter and measure the temp sensor and the throttle position sensor. I think one of them is bad.
Que89YJ is offline
post #6 of 8 Old 05-20-2010, 12:54 PM Thread Starter
reckfield
I don't have a clue as to how to test them. Any suggestions? If not, off to the dealer, yuck!
post #7 of 8 Old 05-20-2010, 01:29 PM
Que89YJ
Idle issues usually are related to IAC and throttle position sensor. If you can get a meter the people on the forum here can walk you through testing it, there are 2 or 3 sensors that are possibly related to it so you can start with the obvious and with the cost of the dealership replace all 3 and still save $$$ or take it to the shop. If you replaced the IAC it sounds like you have the apptitude to figure out whats going on with a little coaching from the forum.
Que89YJ is offline
post #8 of 8 Old 05-20-2010, 04:02 PM Thread Starter
reckfield
Thanks
Thank you for all your help!!!!!!
Heater A/C control unit raygrooms TJ Wrangler Technical Forum 7 02-08-2010 03:33 AM
Need new Ventilation Control Unit???? CAJeepin TJ Wrangler Technical Forum 4 01-24-2009 10:41 AM
Clutch Control Unit ChrisMac YJ Wrangler Technical Forum 2 08-22-2008 04:24 PM
Engine Control Unit Question TexasTJ22 TJ Wrangler Technical Forum 1 12-28-2004 06:15 PM
Heater/ AC control unit RedGlove TJ Wrangler Technical Forum 9 12-22-2004 04:23 PM
