Engine and AW4 swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Engine and AW4 swap
Ruffstuff XJ Unirail Channel Reinforcement....Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6RIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 11-23-2014, 07:20 AM   #1
vgilbertson
Engine and AW4 swap
Morning
I pulled the 4.0 auto out of the 92 YJ a week or so ago. Yesterday pulled the engine out of the donor, 95 xj.
Found where fan, ac and alternator mounts are different so swapping them from the original/
Pulled the wiring harness for the TCU.
Have a question on the transfer case, YJ front dif is vacuum controlled by the transfer case - do I need to install the manual kit? I don't see it referenced in any of the write ups.
Thanks
vgilbertson is offline   Reply With Quote Quick reply to this message
Unread 11-23-2014, 09:57 AM   #2
Jeepsr4me
I would do the cable shifter for the front either way. I never liked having the lines and stuff hanging down there that could get pulled off during my mud runs...
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 11-28-2014, 06:45 PM   #3
nagel
When I swapped out my motor and trans from my 89 YJ, I put in a 96 4.0 from an XJ.
Had to clock the T-case (hangs low otherwise)
Since I chose to use the cherokee NP242, I lost the vacuum actuator. Posi-lock it, or pull the passenger axle shaft from the XJ and swap it (there's plenty of writeups about eliminating the 2 piece axle).
nagel is offline   Reply With Quote Quick reply to this message
Unread 11-28-2014, 07:32 PM   #4
Tshark299
1987 YJ Wrangler
If you're using the XJ transfer case, and it's an NP231, you can keep your vacuum disconnect by trasnfering the vacuum switch over. When I did my 4.0 swap I used the '95 XJ NP231 in my '87 YJ with the vacuum disconnect still.
'87 YJ Laredo - 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
'95 XJ - Donated drive train to the YJ, Parted out the rest
'51 CJ-3A - Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline   Reply With Quote Quick reply to this message
Unread 11-30-2014, 05:35 PM   #5
vgilbertson
I am using a NP231 so will look at transferring the vacuum switch .
Thanks for the help
