Engine for '93 AX-5 YJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Engine for '93 AX-5 YJ
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTHE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 07-06-2014, 07:07 PM   #1
cwein23
The 2.5 L engine in my 93 wrangler went out, so I pulled the engine. Now is time to buy a new engine, but being a broke highschooler wanted to get his jeep running, I wont be able to do a 4.0 swap.
So Im looking for a 2.5 to put in, and I found a 2.5 L from a Comanche.
The shop its at is closed today, but would that be an acceptable swap?
My main concern was if the harnesses, motor mounts, and transmission connections would be the same with the Comanches engine? The post says its for a 91-95 Comanche.
Thanks!
cwein23 is offline   Reply With Quote
Unread 07-07-2014, 02:47 AM   #2
Drednot
Since The Comanche stopped production in 1992, I would be leery of any info from the seller. If its got port fuel injection, it will have the best chance of being compatible. Most likely you will have to strip it down to the long block and transfer all your intake and accessories. Be careful about buying used engines here in the valley unless you hear it run.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is offline   Reply With Quote
Unread 07-07-2014, 09:45 AM   #3
Firefyter-Emt
So easy to swap the intake over, and you benefit from a new intake / exhaust gasket too.
Firefyter-Emt is offline   Reply With Quote
Unread 07-07-2014, 07:56 PM   #4
cwein23
Thank you, I probably wont take the engine anyways. I called today and its not in the state, so Id have to pay for freight down here so its too much.
Thanks for the info anyways!
