Engine - JeepForum.com
post #1 of 3 Old 05-04-2001, 12:47 AM Thread Starter
Nine5YJ
Engine
hey-
does anyone know what the normal engine temp for a 1995 2.5L 4 Cyl is? and also what should I be idiling at?
Thanks!
Tom
95 YJ
95 YJ, 31 x 12.5 ProComp ATs / AR767 wheels, stock 4.10s, 2 1/2" Rough Country Suspension Lift, and huge rusty basketball sized drain holes.
Nine5YJ is offline
post #2 of 3 Old 05-04-2001, 08:19 PM
RatherBeJeeping
Mine runs around 210 degrees. Idle's around 500-600 RPM's, but I've got an inertia ring on the fly wheel.
John
95.5 YJ with "stuff"
RatherBeJeeping is offline
post #3 of 3 Old 05-07-2001, 01:20 PM
jmsjeep
mine runs @ 165, which i've always thought was cool
I wonder were that dirt road goes?
'89 YJ 4 banger all stock, replacing all the worn out guts first, 97 grand cherokee limited
jmsjeep is offline
Engine code p1281, engine cold for too long....which temperature thermostat to use? ShadowLawz TJ Wrangler Technical Forum 11 11-25-2014 12:23 PM
Engine wont turn over, solenoid clicks, hammer tapping starter gets the engine turnin zpmada YJ Wrangler Technical Forum 26 08-16-2011 08:00 PM
post engine wash problems--engine light on.... PatriotCrawler TJ Wrangler Technical Forum 6 06-21-2007 01:10 AM
Service engine light on!! Is it from H20 in radiator & engine coolant compartment?? chaznad TJ Wrangler Technical Forum 12 04-24-2005 09:57 PM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-27-2003 12:43 AM
