Engin dies during fast stops - JeepForum.com
post #1 of 4 Old 02-07-2002, 05:12 PM Thread Starter
BigD
Got a problem with my 89 yj during stopping. When I apply the breaks to stop everythings fine,till I push in the clutch. RPMs fall right off till it stalls. Think its a vacuum leak, but can't seem to find it. Any suggestions???
BigD is offline
post #2 of 4 Old 02-07-2002, 05:44 PM
BTowe
BigD, that may or may not be vacuum related. I had the same thing on my 87. What carb and engine do you have? My 4.2 with Carter 2bbl did the same thing. I even upped the idle some to keep it from happening. The cause I found was a leak in the carb. If you have this set up, I know of a web site that tells you how to repair this leak. It worked for me.
BTowe is offline
post #3 of 4 Old 02-07-2002, 06:25 PM Thread Starter
BigD
Thanks B Towe. I have the same set up you have. Yes I would be very interested in that site to fix the leak. What is it??
BigD is offline
post #4 of 4 Old 02-09-2002, 03:49 PM
NOVA Jeeper56
BigD,
check your EGR,
'94yj, rancho lift kit, 31x10.50 BFG mud's,intake,exhaust,wheels, warn 6000lb winch,lights,
bumpers/brush guard
(used to be known as BiggMike56)
NOVA Jeeper56 is offline
Anyone own a 33 Engin. Skid in CA? MetalguyH TJ Wrangler Technical Forum 5 09-28-2009 11:21 AM
Got my lift on and now my Jeep dies when i get low RPM's or at stops??? Coincidence?! 97casteeltj TJ Wrangler Technical Forum 7 08-29-2008 07:11 PM
jeep engin stoping need help fast litel dart YJ Wrangler Technical Forum 8 11-10-2007 08:02 PM
check engin 11-12-33-55 ebproseller YJ Wrangler Technical Forum 4 06-19-2007 01:15 PM
Check engin light SGT Superman TJ Wrangler Technical Forum 3 10-05-2005 03:02 PM
