Engaging 4WD on 91 Wrangler - Page 2 - JeepForum.com
post #16 of 20 Old 03-06-2013, 07:59 PM
plym49
Originally Posted by GorJess View Post
She said it should be serviced because its only been used a few times.
There is nothing wrong with your 4WD.
They don't go bad from not being used.
Just use it and don't worry.
When spring has sprung, change the transfer case fluid as MGRawr suggested, grease all the zerk fittings, and change front and rear diffs and tranny lube for good measure.
plym49 is offline
post #17 of 20 Old 03-06-2013, 08:01 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Can I change my name to MGRawr? That's pretty legit. Haha.
Michaelgoesrawr is offline
post #18 of 20 Old 03-06-2013, 08:08 PM
AmmitOsiris
AmmitOsiris's Avatar
You will want to make sure the front axle engages via the actuator built ito it. The vacuum lines are prone to decay after all these years so pop it into 4 high and drive ahead in a straight line for three feet. If the 4x4 light comes on you're probably ok. Visually check to see that there are connectors at the cad. If I had a pic of one on a '91 I would post it.
does.it.look like mine? if so I can get some pics....
AmmitOsiris is offline
post #19 of 20 Old 03-06-2013, 08:47 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Just like yours, Jake.
Luck Favours The Prepared
Anticanman is offline
post #20 of 20 Old 03-07-2013, 05:33 PM Thread Starter
GorJess
Thanks guys! Used he 4wd last night and it worked like a champ! No issues xx
GorJess is offline
4wd , newbie , YJ
