EMP proof - Page 2 - JeepForum.com
post #16 of 33 Old 01-13-2014, 07:29 AM
fishadventure
Just for the sake of discussion because I have always found not being electronics-dependent interesting.
A number of people I know and I talked a lot about it around the Y2K debacle.
So basically the Ford Ignition Module from the middle seventies is also vulnerable? That leaves nothing but points to be EOTWAWKI 'compliant'? Hmmm.
And so basically an alternator is also not dependable, but a generator with a mechanical regulator would be?
Shackles and D-rings: different things!
Cranking IS turning over
fishadventure is offline
post #17 of 33 Old 01-13-2014, 07:55 AM
Que89YJ
There are 2 components to electromagnetics;e field(RF) and h field(magnetic). The standard emp field kill most people think of is a mobile transmitter that is keyed on to confuse a computer. That is an efield kill using rf. H field is a whole different issue. It takes a lot of energy to generate H field and the distances are very short. H field travels through almost any surface including metal and h field coupling on any electrical circuit is easy and significant power can be generated. The basic idea that a transformer works on is a good example. If a significant h field is generated the power will travel through the circuit it is intoduced on. If the circuit is exposed and operating it will see the power through the operating path of the circuit and too much power will cause failure. Even with the circuit off a H field event has enough potential to cause the circuit its introduced on to fail. You are just minimizing the effect by turning it off.
No, anything with wiring including the ignition sytem will have an issue with an H field event. Some of the crazy stuff the government has played with like the HARP are ionispheric "heaters" that generate a significant emp pulse that would readily disable any electronics.
If it has wires it will be effected in the h field. E field is almost impossible to be effective in all vehicles at all frequiencies because it is easy to shield for and the frquecies the computers run on is such a wide range that no one freq. would be effective on all computers.
Que89YJ is offline
post #18 of 33 Old 01-13-2014, 04:42 PM
fishadventure
Originally Posted by Que89YJ View Post
...If a significant h field is generated the power will travel through the circuit it is intoduced on. If the circuit is exposed and operating it will see the power through the operating path of the circuit and too much power will cause failure. Even with the circuit off a H field event has enough potential to cause the circuit its introduced on to fail. You are just minimizing the effect by turning it off.
No, anything with wiring including the ignition sytem will have an issue with an H field event. Some of the crazy stuff the government has played with like the HARP are ionispheric "heaters" that generate a significant emp pulse that would readily disable any electronics...
So for clarity: I was under the impression that electronics that were primitive would survive an EMP event to be operable after the cessation of the event, albeit they would not function during the event. i.e. an old transistor radio, CB, tube-based ham radio. And 70s era ECMs, etc.
In other words, what it appears that you are meaning when you said, "If the circuit is exposed and operating it will see the power through the operating path of the circuit" is that even basic wiring 'circuits' will fail during an EMP event and that failure will be full and complete- not a temporary disabling kind of failure... So even an old points-running aircooled VW is not a good plan for an EOTWAWKI bug-out rig in that case!
post #19 of 33 Old 01-13-2014, 05:50 PM
jeepguy85
1987 YJ Wrangler
Que, sounds like you sir hold the good ole EE. Am I correct?
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #20 of 33 Old 01-13-2014, 06:27 PM
ionakana
Grand Poobah
ionakana's Avatar
EMP proof!
Psalm 14:1
Live in Georgia? click here-->
ionakana is offline
post #21 of 33 Old 01-13-2014, 06:44 PM
Que89YJ
I have been doing electromagnetics in form form or another for almost 30 years. Started in the submarines in the military, a few couple years of college, and a lot of OJT doing emc EMC tech at Chrysler for 23 years. People generally have no idea what kind of testing we do for emc.
This is a link to the test lab web site where I work.
http://www.chryslertestservices.com/...ries-list.html
I made sure to qualify the circuits being effected by the h field and being damaged. The h field is very severe but very hard to generate. It takes a huge amount of power to generate that type of field. If you see that type of field there are going to be way bigger things to worry about then the engine starting! The diesel would be your best bet. The military does design systems to withstand the high fields I am talking about but Mu metal to do that kind of shielding and the shielding is truly expensive and prohibitive.
Que89YJ is offline
post #22 of 33 Old 01-13-2014, 08:29 PM
plym49
Don't overthink this. Get a pre-ECU carb and a points distributor. I did. Done and done.
plym49 is offline
post #23 of 33 Old 01-13-2014, 08:51 PM
Bip
1976 CJ5
So, what I'm gathering is that if a h field hits us, nothing will work. But, if we have the vehicle turned off we will still be able to run it after the h field emp? Let's say you are running your vehicle and the h field hits. It fries everything. Wouldn't then the vehicle be salvageable if you stored extra parts in a faraday cage and then installed those parts after the emp hit? And, if that is true, wouldn't it be safer to have an older vehicle so that less of it was fried and it is easier to fix?
Bip is offline
post #24 of 33 Old 01-13-2014, 09:13 PM
Que89YJ
Yes. Exactly.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #25 of 33 Old 01-14-2014, 12:47 AM
Moondog21_2
Good Lord. I thought I wandered off jeep forum for a minute.
Moondog21_2 is offline
post #26 of 33 Old 01-15-2014, 07:57 AM
vadslram
Originally Posted by xeon View Post
Yup all YJs have computers. Most CJs have computers too. Its got to be mad old...
I would not be worried. Because if you go down most everyone around you will too and your cell phone and stuff...
Mine doesn't
It's in a box in the garage attic.
Put a plain jane MC2150 and an HEI unit and your about as apocalypse ready as you can be. Unless you want to be really prepped for doomsday, then you need to turn your garage into a farraday cage.
vadslram is offline
post #27 of 33 Old 01-15-2014, 10:26 AM
superj
my 76 cj5 has all old school parts with no ecu or any type of computer. points distributor and all on its 4.2
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #28 of 33 Old 01-15-2014, 05:17 PM
Bip
1976 CJ5
That's good to hear because ours is a 1976 CJ5, 4.2 also and all original.
Bip is offline
post #29 of 33 Old 01-15-2014, 09:07 PM
plym49
Not necessarily. A device with chips can be harmed even if it is powered off. It depends on the chips/circuit board and the strength of the pulse.
Remember, chip'd devices are running code - computer programs - on very low power circuits. An induced voltage can physically harm a chip just as a bit or two can flip from 'on' to 'off', or vice versa. Mess up one checksum and whatever it is will not work. Do that on the right (wrong) type of chip and the unit might not come back after a reset.
plym49 is offline
post #30 of 33 Old 01-15-2014, 09:08 PM
plym49
Originally Posted by roadyrob View Post
some scientists believe that a vehicle made of steel and sitting on tires acts as a faraday cage so they will operate ,others claim batteries, diodes, coils, etc. will also be bad so possibly something old and diesel powered will work, like a antique farm tractor that will be able to drive around the disabled vehicles.
No scientists would say any such thing, for example lumping batteries and coils with solid-state devices.
If you think I am mistaken, please cite the scientific papers that support your statement along with the credentials of the authors and the results of a peer review.
plym49 is offline
Slim Jim Proof jgorm TJ Wrangler Technical Forum 42 03-08-2010 08:18 AM
can i mud proof 06 tj radiator derrick_ozzy TJ Wrangler Technical Forum 13 05-01-2009 07:27 PM
How water proof.... JeeperAbe TJ Wrangler Technical Forum 11 05-05-2007 11:38 AM
I want to water-proof my CAI for my LJ yj_ryn TJ Wrangler Technical Forum 7 08-28-2006 06:29 AM
Water Proof sharek TJ Wrangler Technical Forum 22 06-09-2005 05:08 AM
