Emmisions Legal? - JeepForum.com
post #1 of 8 Old 07-01-2011, 04:27 PM Thread Starter
tecman
Emmisions Legal?
91 Wrangler with a sick card! Has original carb and runs very poorly sputters backfires etc....! Moved from Nebraska (no emissions tests) to Colorado I now need to replace the carb and need to know what a good replacement would be that will pass the emissions tests in Colorado!
tecman is offline
post #2 of 8 Old 07-01-2011, 11:04 PM
Xpress
Sputtering and backfiring could be from dirty jets on the carb. If I were you, I'd unbolt it and get to scrubbing.
All about that unibody life.
Xpress is offline
post #3 of 8 Old 07-01-2011, 11:07 PM
monkeyhouse
what's a 402? I didn't think they manufactured 4.2's in 90, so just not sure you actually have a carb?
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #4 of 8 Old 07-01-2011, 11:15 PM
5-90
5-90's Avatar
1988 XJ Cherokee
The AMC 6-258 was produced until the end of the 1990 model year, used in the YJ. It remained carburetted - but the 6-242 head and top end can be swapped on and the engine converted to fuel injection.
Only the YJ had the 6-258, 1987-1990. It overlapped those years with the 6-242 in the XJ and MJ.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #5 of 8 Old 07-01-2011, 11:23 PM
monkeyhouse
thanks, awesome info as usual mr. 90! still not sure what he is referencing as a stock 402 though?
post #6 of 8 Old 07-01-2011, 11:39 PM
1986cj
He most likely means a 4.2 not a 402. YJs didn't get the 4.0 in tell 91, first year for a 4.0, HO, fuel injection and a obd1, They never put a 4.0 renix in a YJ.
1986cj is offline
post #7 of 8 Old 07-02-2011, 12:10 AM
monkeyhouse
I figured, just thought maybe somehow someone put it in after and he thought that was stock. Thanks again!
post #8 of 8 Old 07-02-2011, 07:36 AM
jay-h
If you're dealing with emissions your best bet is to stay strictly stock. The running problems may or may not be related to the carb, you can get a replacement for about 180.
Using this as a guide, make sure everything is hooked up and set correctly.
http://home.sprynet.com/~dale02/
jay-h is offline
Emmisions comp. UserX YJ Wrangler Technical Forum 3 03-25-2010 02:00 PM
Emmisions Opinions Nelli769 YJ Wrangler Technical Forum 0 06-17-2009 05:02 PM
A little emmisions problem. JohnyWalker TJ Wrangler Technical Forum 2 03-18-2009 02:16 PM
Emmisions laws bryris YJ Wrangler Technical Forum 2 08-07-2006 06:45 PM
Emmisions Yikes!!! jeeptrickABQ YJ Wrangler Technical Forum 15 05-25-2005 12:29 AM
