Emissions Maintenance Indicator Light on 92 YJ - JeepForum.com
post #1 of 12 Old 05-07-2002, 08:24 PM Thread Starter
Shifty
This is a 92 YJ 4.0L. According to my Haynes manual at roughly 82,500 miles my Maintenance Indicator Light should come on. Sure enough at 82,580 my light came on. I know the oxygen sensor is relatively inexpensive and simple to change. However, the manual talks about buying a special tool to reset the maintenance indicator light under the right side of the dash. Is there a way around buying the tool vs going to a dealership? Anyone got any ideas? Bubble gum, paper clips, wack it with a hammer? :-)
Shifty is offline
post #2 of 12 Old 05-07-2002, 09:48 PM
flashJP
hey, ive got an '89yj and had the same deal. there is a timer that counts 2 things; miles and engine hours...at 82,500 miles or so, it should make your emiss. maint, light go off, and thats what it did...
WHAT you should do..replace your O2 sensor...cost ya about 45 bucks, and its fairly easy if you know you way around your jeep..
WHAT you dont really have to do, worry about that timer...what i did was replace my O2 sensor and actually took out the timer unit, its fairly useless and would be a waste of money, ALL it does is count miles & engine hours...
all you have to do is be aware of the miles on the new O2 sensor and you'll be fine...save the cash!!!
hope this helps
1989 Wrangler YJ Red
4-cyl 2.5 L
AX-5 (5spd)
15x7 OutLaw II
NEW: distributor cap,rotor,spark plugs,wires,fuel filter,ccv&pcv, steelhorse console...
flashJP is offline
post #3 of 12 Old 05-08-2002, 01:15 AM
93 Blue Demon YJ
Yeah, that timer is stupid. I wish they (Jeep) would have spent the money a little wiser. Its there to freak you out and to make you go to the Dealer and get a $150 O2 sensor. Take either the timer or the bulb out and go to Autozone and get good Bosch O2 sensor for about $40. Thats even what my Hayes repair manual says to do.
Richard
'93 YJ 4.0 3" RC lift 15x10 wheels and 32" tires.
93 Blue Demon YJ is offline
post #4 of 12 Old 05-08-2002, 02:40 AM
Sarge37
The easiest thing to do is remove the 2 screws that hold the idiot light panel (Center plastic cover) And remove the bulb. The 91 and newer YJs dont have that mileage timer thing under the dash.
"If It Aint Broke, Fix It Till It Is!!!!!"
05 TJ Rubicon, 4.0L, 6 Speed.
07 Ram 1500 Quad Cab
Sarge37 is offline
post #5 of 12 Old 05-08-2002, 07:42 AM
Prime Lord
Prime Lord's Avatar
Location: Chesapeake, VA (My office is just hell w/ florescent lighting)
Mine just came on too.....Isnt there a way I can get rid of it w/o removing the bulb or going to the dealer?
~Jay
, 4.0, 5-speed. 1" Daystar Body Lift, 31x10.50 Goodyear MT/R's, CJ Style (87-91) Roll Bar, ARB Safari Snorkel, K&N Panel Filter, Dynomax SuperTurbo Catback. Still hunting for TJ Sahara flares!!!
, Maximum Motorsports: Rear LCA's, 4-point K-Member brace, & Std Length Subframe Connectors, FRPP 'C' Springs, Mac Pro-Chamber, Chrome BBK equal length shorties, B&M Ripper w/ leather cobra knob.
Prime Lord is offline
post #6 of 12 Old 05-08-2002, 08:28 AM
flashJP
disconnect the timer. no power to it, no problem.
4-cyl 2.5 L
AX-5 (5spd)
15x7 OutLaw II
flashJP is offline
post #7 of 12 Old 05-08-2002, 08:28 PM Thread Starter
Shifty
Thanks guys! I put in a new O2 Sensor this afternoon. Autozone had it but it was 50 bucks, no bigge. As for the dash light, I will figure that out some other day.
Shifty is offline
post #8 of 12 Old 05-11-2002, 02:39 PM
Wildbill
Wildbill's Avatar
Mine is on also, right around 82,000. I have disconnected the battery hoping this would reset everything with no luck. How do I pull power on timer and where is it? I will replace to O2 sensor soon but want to get rid of that friggin light.
Yale H.
Club President
Peace River Jeepers
Blue Jeep Club Member #23
'92 Blue YJ 4.0 HO, 5spd.
'04 Bright Silver Liberty Sport 4X4 3.7L Stock for now
What do a Divorce in Alabama, A Tornado in Kansas and a Hurricane in Florida all have in common?.....No matter what someone is fixin' to lose a trailer
Wildbill is offline
post #9 of 12 Old 05-11-2002, 04:13 PM
flashJP
the timer is located below the dash, and to the right of the sterring column. at least thats where it is on the 89 YJ..the timer is a plastic box that almost looks like a thermostat...it should have wire connected to it, just disconnect and "retire in place".
hope this helps
4-cyl 2.5 L
AX-5 (5spd)
15x7 OutLaw II
flashJP is offline
post #10 of 12 Old 11-27-2013, 09:21 PM
YJ4LIFE
hope this helps
anyone have a picture of this? I'm doing efi swap and I want that light to be my check engine light.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #11 of 12 Old 11-28-2013, 08:02 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Here you go;
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #12 of 12 Old 11-29-2013, 07:38 AM
fishadventure
I just pulled the bulb in my 89 the other day. I moved it to the high beam indicator position as that bulb was blown. It was a very useful and satisfying mod LOL
Shackles and D-rings: different things!
Cranking IS turning over
fishadventure is offline
fog light indicator light wiring questions. rocknjeep YJ Wrangler Technical Forum 4 12-27-2009 10:16 AM
4wd indicator light TJmooker TJ Wrangler Technical Forum 3 01-11-2008 01:58 PM
4WD indicator light? Saturntech45 TJ Wrangler Technical Forum 9 12-08-2006 08:23 AM
4x4 indicator light NOT on... *PIC* rolledthatho YJ Wrangler Technical Forum 12 01-30-2006 01:18 PM
4 wd Indicator Light ?? bigjeep39 YJ Wrangler Technical Forum 2 05-03-2002 04:47 AM
