Which emissions lines can you get rid of? - JeepForum.com
post #1 of 4 Old 10-24-2008, 06:49 PM Thread Starter
Timkat
We have a 89 YJ and the guy we bought it from put on a performance air filter and did all sorts of capping or vacuum lines.....the jeep sputters on acceleration and wont go above 55...
So we put the original air filter on connected the pcv valve as it should be....still very confused on what lines are what....
Can anyone describe or provide pics of non-essential emissions/vacuum lines that we don't have to worry about?
Any help would be great-Thanks
Timkat is offline
post #2 of 4 Old 10-24-2008, 07:42 PM
jay-h
Go here
http://home.sprynet.com/~dale02/list.htm
Learn about what is supposed to be there and what it does. Then you can make some educated guesses. My recommendation is put back everythign you can, then remove stuff one a time if you want to experiment.
jay-h is offline
post #3 of 4 Old 10-24-2008, 07:47 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Read this.
http://jeeps.hallbergs.com/nutter.htm
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 4 Old 12-26-2008, 07:54 PM
Neighborbill
gut it all
Neighborbill is offline
ECM low emissions/std emissions difference? perfectcircle TJ Wrangler Technical Forum 5 01-29-2010 03:06 PM
(2.5L swap) What emissions/vacuum lines can be eliminated? rain-gler YJ Wrangler Technical Forum 1 08-26-2009 07:04 PM
Ca. Emissions vs Non Ca emissions certified wanabxtrm JK Wrangler Technical Forum 1 11-22-2008 08:44 AM
Need braided steel fuel lines (from tank to frame lines) drew2000 YJ Wrangler Technical Forum 4 06-18-2006 09:38 AM
Anyone kone the differance between Calif. Emissions vs. Standard Emissions? Missin44 YJ Wrangler Technical Forum 2 04-26-2002 11:37 PM
