Emissions Failure : 89 Jeep HC & CO - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Emissions Failure : 89 Jeep HC & CO
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !
Unread 04-27-2009, 05:12 PM   #1
sports100
Ok guys I live in spokane wa. I went to buy tabs today and had to get emissions testing done. I went thinking i'd pass but silly me, i own a jeep . So I am now coming to you for all the love and concerns of my own. What i failed on was my HC (PPM) or Hydrocarbons at a Cruise limit at 25mph. I did pass "HC" at an idle. The Limit for Hydrocarbons at Cruise was 150 and i failed as a 241. Now I also failed on my CO or Carbon Monoxide i believe while at an idle. I did pass the CO at cruise. But at the Idle the limit was 1.2 and mine showed up at a 2.28 FAIL.
I read past emissions but its seems people have very specifics on the vehicle so I believe mine has a possibility of being something completely else.
So My Jeep Is a 1989 Wrangler Sahara, 4.2L , manuel, 142,000 miles. Any help would be nice. Im guessing your all gonna say catalytic, tune up, 93 octane, 1/4 tank it, and high rev the **** outta it to burn everything alive inside the exhaust prior.
BUT id like something more, promotional like Actually fixing the issue at hand. Thanks
JOe
89 Jeep Wrangler Sahara 4.2L, pretty much bone stock
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)=@=)_)
sports100 is offline   Reply With Quote
Unread 04-27-2009, 05:45 PM   #2
laybackman
laybackman's Avatar
JOe
Cat converter is the first best guess, oh, about 75% of the time. Then a decent tuned engine along a properly adjusted carburetor and clean air filter goes a long way to getting it passed. Your tank can be full or 1/8 full of gas - don't make no difference. BUT, 93 octane is HARDER for your engine to burn, so it makes those bad numbers your engine 'blew' even worse. If you rev the **** out of it you will probably swallow a valve or run a connecting rod through the base pan but not get it pass the inspector. Make sure it is running in the right temperature range also. Hotter engines run cleaner. So if you got the thermostat pulled put it back in.
Life is like a coin. You can spend it any way you wish...but you can only spend it once.
"If we cannot afford to take care of Veterans, then we should stop making them."
David C. Wilker Jr. USAF (RET)
laybackman is offline   Reply With Quote
Unread 04-27-2009, 05:50 PM   #3
sports100
So here's a new guess. Because i bought thte posi-lok 4wd kit that makes me able to remove a couple vacuum valves. i removed one that went to the round bowling ball object that bolts onto the inner wheel well and maybe one other which even then while pulling off, felt like the wrong things. but would that throw off both HC and CO? As well as is there any way to fix that since i threw that stuff away or do i have to buy another bowling ball vaccuum thing to connect the hose to again and the other little things that went on the hose to reduce the vaccuum. i might have really F%#$D up.
/l , [____],
()_) ()_)=@=)_)
Unread 04-27-2009, 07:43 PM   #4
73Dart
Here ya go. It is a vaccume resevior, I know that it dosen't look the same but the theroy is the same.
http://home.sprynet.com/~dale02/vac-res.htm
http://home.sprynet.com/~dale02/list.htm
I know that this focuses on the CJ but the system is the same as the wrangler.
89 YJ with a 5.2l V8, 5 Speed ax-15, RC aals giving me 1.5" of lift plus 1" lift shackles giving me a total of 2.5" of lift, 31x10.5x15 A/T tires, no carpet, rinolined tub, Family style roll bar.
My motor swap thread
73Dart is offline   Reply With Quote
Unread 04-27-2009, 07:52 PM   #5
dezertdude
Junior Member
Yes a vacum leak could raise the hc and co readings because the o2 sensor would see it as lean and richen the mixture to compensate for it. In California you never would have passed the visual without all that vacum crap hooked up but you should be able to block off all lines associated with it so there is no leak and it might be ok
dezertdude is offline   Reply With Quote
Unread 04-27-2009, 09:11 PM   #6
sports100
ya i no that tin can thing. and i thought that might be it. but can it be round style? like the bowling ball i say. i am not with my car right now to check but im pretty sure i blocked off all lines when i went and removed the stuff. thanks for all input so far. are there any diagrams of the pieces that complete the vacuums
edit: found schematics
/l , [____],
()_) ()_)=@=)_)
Unread 04-28-2009, 07:37 AM   #7
laybackman
laybackman's Avatar
The round ball thing might be the vacuum reservior for your cruise control.
Unread 04-28-2009, 09:12 AM   #8
73Dart
Yea the can and the black ball are the same thing. The vac resivior is used for the emmisions and can be used for cruise as well.
Unread 04-29-2009, 09:29 PM   #9
sports100
So im gonna buy the parts im missing tomorrow. and today i relized like every wire was wrong, as if someone took the engine apart and just threw all the wires back together. If im wrong then i just messed it all up lol. but by looking at the schematics and being that the schematics are correct, someone just had a lil to many coors and not enough genius. so ill let you guys no if i pass after i put the missing parts in
/l , [____],
()_) ()_)=@=)_)
Unread 04-29-2009, 09:42 PM   #10
fireshadow
if you can come up the cheese upgrade to the team rush mod w/ coil and possibly a motorcraft 2100. I did these and my numbers were unbelievably low on a 88 almost as good as my wife's 06 HHR and no more vacuum lines )
1988 Jeep Wrangler, home made posi lock, team rush upgrade, motorcraft 2100 carb, warn m8000 winch, np231c front yoke, rc 2.5" lift, 1" lift shackles
Even my motorcycle has a square headlight(1984 Honda Saber)!!!
fireshadow is offline   Reply With Quote
Unread 04-30-2009, 04:15 AM   #11
Burnerman
The ball is the vacuum resiviour. I have one in the garage that I pulled out from my cruise control removal. PM me if you need it.
What other stuff did you remove? The 4wd disconnect vacuum lines have nothing to do with emissions as long as you just cap the red manifold vacuum line at the first connection tee when you follow it from the transfer case to under the hood. The switch on the firewall is for the 4wd indicator light.
[SIZE="3"]89' YJ Larado 4.0L,AX15
01' Grand Cherokee 4.0L
[/SIZE]
Check my Gallery for pics.
[URL="http://www.jeepforum.com/forum/f12/my-unbuild-rebuild-988762/"]My Rebuild Thread[/URL]
[SIZE="2"][COLOR="Blue"]Take a minute and fill out your profile, Please[/COLOR][/SIZE]
Burnerman is offline   Reply With Quote
Unread 04-30-2009, 07:53 AM   #12
laybackman
laybackman's Avatar
WHOA THERE PARDNER!!! Your jeep may have been (John) Nuttered. The previous owner may have bypassed the useless emission system that they used on these older Jeeps. You might have a timing problem since timing a nuttered jeep is not in any shop manual. You need to confirm that your jeep has in fact been nuttered. Keep in mind you may have a bad carburetor or one that needs tuning also. It is hard to say sitting on my butt here
Then there is a bad catalytic converter which causes most of these emissions problems.
Here are just a few links to 'nuttering'
http://www.billhughes.com/mirror/nutterbypass.htm
http://home.sprynet.com/~dale02/ignmods.htm
Unread 04-30-2009, 10:48 AM   #13
sports100
Thanxs latbackman. but no it never looked anything like diagrams you just gave me either.
Burnerman - Im gonna see today about the vacuum reservior, if no one has it you will get a pm, thanks. I did redo all the hoses yesterday so i did relize that was the only mistaken thing i took off. Probably just cuz it looked so fricked "GAY"
/l , [____],
()_) ()_)=@=)_)
