EMISS MAINT Light - JeepForum.com
post #1 of 5 Old 04-04-2002, 11:04 AM Thread Starter
Hendrickson
EMISS MAINT Light
any recommendations on how to remove this...?
Thanks
Hendrickson is offline
post #2 of 5 Old 04-04-2002, 02:19 PM
dcbeer
need a litle more info... Year and Engine???
If it is a 4.2 from the late 1980's I believe you can unplug the timer, it is on the firewall next to the heat duct (I think)
1988 yj, computer bypass, webber carb and the ever famous BA10/5 transmission (if you have one you know it or will find out).
dcbeer is offline
post #3 of 5 Old 04-04-2002, 02:45 PM
flashJP
why do u want to remove it?
mine was on for a while, turned out to be a timer that tracks miles and engine hours was up and that made the light go on and stay on---i just took out that timer and solved the emiss maint light prob
1989 Wrangler YJ Red
4-cyl 2.5 L
AX-5 (5spd)
15x7 OutLaw II
NEW: distributor cap,rotor,spark plugs,wires,fuel filter,ccv&pcv, steelhorse console...
flashJP is offline
post #4 of 5 Old 04-04-2002, 03:32 PM Thread Starter
Hendrickson
Thanks for getting back to me... Its an 89 4 cyl... I ended up going in the dash and pulling out the bulb.. all set now..
thanks again
post #5 of 5 Old 04-04-2002, 06:19 PM
dcbeer
that will work too...
dcbeer is offline
'89 Emiss Maint Light snidave02 YJ Wrangler Technical Forum 3 02-04-2008 08:52 AM
EMISS MAINT Light kbazurpe YJ Wrangler Technical Forum 7 10-03-2006 08:34 AM
90 YJ "emiss maint" light Bobbywolf YJ Wrangler Technical Forum 2 08-27-2004 11:33 AM
Emiss Maint. Light Dan Morera YJ Wrangler Technical Forum 3 07-15-2002 12:09 PM
EMISS MANT light flashJP YJ Wrangler Technical Forum 5 03-26-2002 07:51 PM
