Emis Maint - JeepForum.com
post #1 of 2 Old 02-14-2002, 09:33 PM Thread Starter
BlueFlyz_Yj
Emis Maint
This emmisson matinece light came up in my 4.2l yj. Is it the o2 sensor?or what?
Remember...it takes 42 muscles in your face to frown ,BUT it only takes 4 muscles to extend your arm and *****-slap the mother****er upside the head:-!
BlueFlyz_Yj is offline
post #2 of 2 Old 02-15-2002, 10:50 AM
JeeperJay
The light is set to come on at a certain mileage. There is a module that needs to be reset or replaced in order to shut that light off. Its just a reminder telling you its time to replace some of your emissions components such as the o2 sensor. The cheapest solution is to just pull the bulb and replace the o2 sensor when you see fit. If you take it to the dealer they may be able to reset the module, but according to my service manual the module needs to be replaced and it will just light the bulb up again at some set mileage. So unless you want a hefty bill from the dealer I'd just take out the bulb.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
150k maint???? wildride89 YJ Wrangler Technical Forum 8 09-22-2009 07:02 AM
Maint. Manuals Vitalidle YJ Wrangler Technical Forum 12 12-13-2007 07:29 AM
Soft Top Maint. dnabadie TJ Wrangler Technical Forum 15 08-12-2005 05:00 PM
my emis maint light came on EMT YJ Wrangler Technical Forum 4 05-24-2005 01:56 PM
Maint. Questions etwolfe7 TJ Wrangler Technical Forum 3 02-06-2005 12:05 PM
