:!emergency!: i need a new flywheel - JeepForum.com
post #1 of 9 Old 04-06-2010, 04:08 PM Thread Starter
bigorangeyj
I need a new flywheel, but I don't know if I need one with trigger teeth, or one without. If its any help, its an 87, 4.2, 5 speed, laredo. I can also send a pic through text or email if it'll help. Please I need help asap.
bigorangeyj is offline
post #2 of 9 Old 04-06-2010, 04:27 PM
FOURWALLYS
Can you pull the starter and see from there? 20 minute job on and off.
I have a love/hate relationship with my jeep. I love it, it hates me..........
FOURWALLYS is offline
post #3 of 9 Old 04-06-2010, 04:36 PM Thread Starter
bigorangeyj
I've already got the starter off, and the tranny on the ground, what's your email, I'm doin this on my phone so I can't post pics but I can do it through email or text
post #4 of 9 Old 04-06-2010, 05:43 PM
Alfons
You should be able to put any 4.0 or 4.2 liter flywheel on that engine. The flywheel bolt pattern and size are the same, the notches for the crank position sensor won't matter since you don't use one, so as long as the ring gear has the correct number of teeth (and I believe that they do), you should be good to go. I fitted a flywheel from a 2005 4.0 onto a 4.2 and put a YJ flywheel onto the 2005 (I converted the 2005 to OBD1 and needed to YJ style notches).
Alfons is offline
post #5 of 9 Old 04-06-2010, 09:30 PM Thread Starter
bigorangeyj
ok i got it, the problem was that i didnt know what trigger teeth were. fyi i didnt need them.
id say its got a few hard spots
post #6 of 9 Old 04-06-2010, 09:35 PM Thread Starter
bigorangeyj
heres where i had a little trouble getting a bolt out.
heres everything on the ground once i finally got it out.
post #7 of 9 Old 04-06-2010, 09:37 PM Thread Starter
bigorangeyj
so im picking up my new flywheel and probably master cylinder tomorrow around lunch time, and hopefully will take it out tomorrow night.
post #8 of 9 Old 04-07-2010, 09:31 AM
FOURWALLYS
Any way you can attach pics, for some reason I can't see them. I'm doing my clutch in 2 weeks and am studying up as much as possible before I tear into it.
post #9 of 9 Old 04-07-2010, 12:19 PM
BlackRhino
BlackRhino's Avatar
http://webmail.aol.com/31226-111/aim-6/en-us/mail/get-attachment.aspx?uid=40000841&folder=Inbox&partId=1
http://webmail.aol.com/31226-111/aim...Inbox&partId=2
You can't just link to images that are in your email. They need to be put on a site like photobucket first.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline
TJ-Need flywheel? jeepwrangler97 TJ Wrangler Technical Forum 4 07-12-2009 08:13 PM
Flywheel on an 87 w/ an I6 87YJinCincy YJ Wrangler Technical Forum 15 11-19-2007 08:31 AM
4.0 Flywheel - what the...? VisitorJim TJ Wrangler Technical Forum 5 04-17-2006 01:01 PM
Sae flywheel/flywheel housing sizes DieselWrangler TJ Wrangler Technical Forum 1 12-30-2005 04:31 PM
YJ Flywheel and CPS TIM92300 YJ Wrangler Technical Forum 3 07-14-2004 08:54 AM
