emergency flashers switch on YJ 92 - JeepForum.com
post #1 of 1 Old 09-19-2012, 11:09 AM Thread Starter
shu2kill
hey.... some time ago ( a lot actually), the switch for the emergency flashers broke... i dont know how, my brother hit it with his knee, and he broke it... i have tried to find it, but i live in mexico and i havent been able to get it. so i want to wire an external switch... i know how to wire switches as i have wired several aux lights, what i dont know is where to get to the cables that feed the blinkers... has anyone done this before?? im assuming there must be a couple of cables behind the firewall, or under the steering wheel, that go to the originall switch... i would like to splice them and install a normal push switch to make the contact....
BTW the original switch is the one on the right side of the steering wheel, the one you pull to activate the blinkers and push to turn them off...
shu2kill is offline
Emergency Flashers work only with the key on knightsog TJ Wrangler Technical Forum 2 09-28-2008 04:19 AM
Headlight short, or fuse? Same with emergency flashers!? ArrizX TJ Wrangler Technical Forum 9 08-31-2008 05:46 PM
No turn signals or emergency flashers on my '99 zrtman TJ Wrangler Technical Forum 5 09-13-2006 07:26 PM
4 Way Flashers RkSldr TJ Wrangler Technical Forum 2 03-19-2006 04:43 AM
turn signals, emergency flashers firefitr26 TJ Wrangler Technical Forum 5 06-09-2004 03:41 PM
