emergency brake wont hold - JeepForum.com
 1Likes
post #1 of 16 Old 02-17-2013, 05:49 PM Thread Starter
mturner0111
I'm in the process of getting my brakes on my 95 yj working again and the parking brake will not hold when I put it in all the cables seem to work and hold but the brakes don't engage anybody have and idea where I could start at to figure out the problem
mturner0111 is offline
post #2 of 16 Old 02-17-2013, 06:01 PM
Dake
Dake's Avatar
Ajust the shoes then the cables
Dake is offline
post #3 of 16 Old 02-17-2013, 06:04 PM
codefiant
I had this problem with my Jeep for about 10 years. I finally sprayed a bunch of wd-40 on the mechanism above the pedal, loosened it up and then "presto", it suddenly worked again.
1988 Wrangler w/ Chevy 5.3L V8
codefiant is offline
post #4 of 16 Old 02-17-2013, 06:14 PM Thread Starter
mturner0111
I've adjusted the cable under the jeep where its tight with no slack and the shoes also to where they have resistance when turning do they need to be tighter and also what do I need to spray on the pedal assembly?
post #5 of 16 Old 02-17-2013, 06:40 PM
jokerchief462
Check this site and see if the recall was ever performed on yours.
http://www.jeep.com/webselfservice/j...ecall&country=
They had one for brakes, emergency brakes.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #6 of 16 Old 02-17-2013, 11:17 PM
Dake
Dake's Avatar
Did you get a new E-brake their is a recall on the pedal assembly?
Dake is offline
post #7 of 16 Old 02-17-2013, 11:31 PM Thread Starter
mturner0111
Was the recall for all 95 wranglers and if mine does qualify how do I go about getting it fixed?
post #8 of 16 Old 02-17-2013, 11:55 PM
Dake
Dake's Avatar
Call the dealer they can tell you if your jeep has had a new one by the vin.
Dake is offline
post #9 of 16 Old 02-17-2013, 11:59 PM
Dake
Dake's Avatar
It may have nothing to do with your problem but if it need a new one they will fix you up. Did mine no charge! I was trying to find some part and the guy looked up told me about it. Only time it been back to the dealer.
Dake is offline
post #10 of 16 Old 02-18-2013, 12:35 AM Thread Starter
mturner0111
Can I just call any jeep dealer?
post #11 of 16 Old 02-18-2013, 12:48 AM
Dake
Dake's Avatar
Yea any jeep dealer should be able to he;p you. They get payed for the work from the Jeep. They had a list of stuff they wanted to fix. I did not let them. No thanks just the e-brake
Dake is offline
post #12 of 16 Old 02-18-2013, 06:26 AM
nembudonna
I have a 94 and the cable was to long to work. They fixed it no charge. But the cable is to long to work. They can't back down. Good Luck.
nembudonna is offline
post #13 of 16 Old 11-28-2016, 02:25 PM
cdmoye
I came here looking for help with an e-brake that won't hold, and found your recall link. Mine's been fixed before. BUT, there is an open recall on a fuel level sending unit gasket. My fuel readings aren't accurate, and I'll just bet that if I take it in for that recall, I can bring in a new sending unit and have the dealer slap it in for not a big upcharge. Save me taking it apart!
Thanks for that link!
cdmoye is offline
post #14 of 16 Old 11-28-2016, 02:57 PM
mike134
Mine had all of the parking brake problems when I first got it. Pads worn down (and split), rust seized star wheel, and cable needed to be adjusted underneath the vehicle near the fuel filter.
Start by taking the rear wheels and drums off. You may as well check for worn brake shoes anyway. I think mine cost about $6 on rockauto, so feel free to put some new ones in at this point. Changing the shoes involves removing the star wheel, so make sure it spins freely in your hand. If it doesn't, I had to use a ton of PB blaster, and blow torch with heating/cooling cycles to free it up. I then greased the inside of the star wheel with anti-seize so it doesn't happen again.
Don't tighten the brake cable until your shoes and star wheels are in good condition.
mike134 is offline
post #15 of 16 Old 11-28-2016, 03:44 PM
dancytron
Here is a video on how to take apart the rear brakes.
Get the special tools. They are $15 at Harbor Freight. It isn't safe to work on without them.
Also, wear safety glasses. You don't want to be the guy in the ER with the spring in his eye.
If it is rusty in there, the kit with all new springs and parts is only like $25.
gotswap likes this.
dancytron is offline
