#1 | |
Elmers Glue in my gas tank -- Advice.
I accidentally poured Elmer's Glue into my YJ's gas tank.
It happened because I found a bottle of Lucas engine cleaner lying around and I saw it filled with liquid. I don't know the color of Lucas, so when I saw the white liquid inside the bottle, I assumed it was Lucas and not glue. So I pour it down the gas tank and then it smells like glue. However, before I stopped, some glue got into the lines, but I don't think it made it to the tank. The glue was rather thick, probably cause it was so old. I cleaned up some of the glue in and around the gas tank and dismantled a few parts to get a better clean, but I did not remove the fuel hoses. The amount of glue that got in is about a teaspoon of glue, if that. Help! What to do here?
#2 |
The gas will disolve it. Just drive on.
#3 | |
That small amount shouldn't cause any harm.
Elmer's is a water based glue and the worst that might happen is it will just lay in the bottom of the tank. Take some gas in a jar and pour a little Elmer's in it and see what it does. Quote:
All other things being equal, the simplest solution is the best. Ich liebe meinen Jeep! |
#4 |
First off WOW you poured something in your tank before you knew FOR SURE what it was?
OK with that said it is probably a little late now but I would agree gas will disolve the glue. So I would go fill my fuel talk and by gas going into the tank any glue in the fill line will be disolved. Thats then drive around some so it will circulate through all the lines and break up any glue in the line
Built 92 XJ For Sale |
#5 | |
ISO 9001 Compliant
Do this before doing anything else. If it disolves, great. If it clumps into a ball then you might have to drop the tank and clean it out. good luck
. . "The right to be heard does not necessarily include the right to be taken seriously." —Hubert Humphrey . If you live within wheeling distance of San Diego county, click here |
#6 | |
Lol, that title is classic... Watch the glue give him another 50 horses and 30 mpg.
Sniper Central Quote:
#7 |
I'll bet if he said it did there would be those that would try it.
#8 | |
H2 Recovery Team Member
RIP: '88 YJ 2.5L Ax-5 NP231 Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front. 92 YJ 4.0L Ax-15 231 5" springs, 1" shackle 31's or 35's depending on my mood |
#9 |
I've poured some Elmer's Glue into a jar and mixed it with gas.
So far, the glue has dissolved very little and managed to turn into a very liquidy white substance that is beginning to show signs that it will dissolve. I'll post updates. Thanks for the help. |
#10 |
and pictures
I want pictures.
His goal in life was to be an echo The type of sound that floats around and then back down Like a feather Ask me anything Follow me on Twitter, you know you want to. Insomniac? Join the Nightcrew |
#11 |
If anything the glue got stuck to the inside of the fill tubes.
1993 Black YJ All Terrain 33's-4 inch RC lift Revolver shackles- some other stuff |
#12 |
duhhhh huhh huhhh
11 JK 2.5" RC BB 33X12.50 Duratrac and a few mor goodies |
#13 |
ISO 9001 Compliant
Didn't they used to make glue from old horses? I always heard the expression about sending them off to the glue factory. So, what better way to add horsepower directly to your engine.
#14 |
Why take the chance. drop th tank and replace the filter while you are there. then make your tank a 20 gal by pulling the tube. Beats getting stuck later, and peace of mind is worth the two hours time.
Judging from your experiment your filter will plug up soon anyway. |
#15 |
XJ on 37's
now watch all the 4 banger crowd go running to the local hobby store.....
![]() as always, excellent suggestion pat! ![]() martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee.... 1998 Range Rover 4.6 HSE 2000 4.7 4WD WJ with a rebuilt motor. 4.3/700r4/new frame buildup (YJ).... http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/ Years to gain the hands on experience, and offer it freely. Minutes to gain the knowledge from the internet, and quote it just as freely. Choose wisely! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
