Electronic Speedometer on a 91 YJ - JeepForum.com
post #1 of 4 Old 10-27-2006, 07:44 PM Thread Starter
Mr. Tobes
I bought an electronic speedometer from autometer and can't figure out how to install it. The 91 YJ originally had a mechanical speedo, so the wiring harness has no wire for the speedo. But I put a new transfer case on which has an electronic sender. Summit has a sender, but I am not sure if it will work. It look like a mechanical to electronic adapter. It can be found here:
http://store.summitracing.com/partde...0&autoview=sku
If this won't work, how do I go about hooking this badboy up?
Thanks
Mr. Tobes is offline
post #2 of 4 Old 10-28-2006, 05:28 PM Thread Starter
Mr. Tobes
Does this make sense to anyone? Please let me know if I need to clarify something.
post #3 of 4 Old 10-28-2006, 05:44 PM
bobbert350
bobbert350's Avatar
hmm..dont no much about them but buy what u need.. i belive thats what u need here are the install insturctions
http://static.summitracing.com/globa...s/atm-5291.pdf
bobbert350 is offline
post #4 of 4 Old 10-28-2006, 10:22 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
does the gauge manufacturer not make a harness for it?
electronic speedo's work off a pulse system i think, and you would need to match the pulses to the gauge.
otherwise the cheapest option would be to trace the wiring for an electronic speedo in the shop manual.....basically it needs a power feed, then the wire to the gauge. there will be wire(s) to the ecm also, but you will prob b ok to bypass these, as they would mainly be used for the cruise, auto tranny etc.
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
will cable driven slip yoke work with electronic speedometer? nnojeeps YJ Wrangler Technical Forum 4 10-19-2009 10:49 PM
electronic speedometer calibration: a writeup tcox TJ Wrangler Technical Forum 0 09-08-2008 10:44 AM
Swapping out mechanical speedometer for electronic one. Oorin YJ Wrangler Technical Forum 3 01-31-2008 08:13 AM
Convert AX15/NP to electronic speedometer? Fred007 YJ Wrangler Technical Forum 3 10-25-2007 07:09 AM
Electronic Speedometer COJAM YJ Wrangler Technical Forum 19 03-22-2005 03:15 PM
