Electronic Speedometer - JeepForum.com
post #1 of 20 Old 03-21-2005, 11:27 AM Thread Starter
COJAM
COJAM's Avatar
Does anyone have any experience with an electronic speedometer sender and a NP231? I need to know that the thread size is where the cable goes into the t-case. Nothing on dash is stock so I am adding an electric speedo.
GBD
COJAM is offline
post #2 of 20 Old 03-21-2005, 01:03 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
The cable doesn't go into the tcase. There is a plastic unit that goes in the tcase, and the speedo cable attaches to that. On later years (like my '93), the plastic adapter has an electrical connection on it. The 3 wire circuit is Plus/Gnd/Sig. The Sig line flops back and forth between Plus and Gnd with 8k pulses/mile. My Jeep had the Plus fed from the PCM as 8V. After I swapped my motor (new PCM), I used a normal 12V line for Plus and all works fine.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #3 of 20 Old 03-21-2005, 02:36 PM Thread Starter
COJAM
COJAM's Avatar
Huh? I wonder if I could just get a sender for a 93 and up and use it with an autometer speedometer.
GBD
COJAM is offline
post #4 of 20 Old 03-21-2005, 02:38 PM
sjlplat
...Or you could go with a GPS speedo and never worry about cables or sending units again.
sjlplat is offline
post #5 of 20 Old 03-21-2005, 02:58 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Do they have output lines to feed the VSS sig to the vehicle's PCM?
Web Admin for
post #6 of 20 Old 03-21-2005, 03:30 PM
sjlplat
Don't know about that one. The ones I've seen are a 3-wire connection. Positive power, Ground, and background lighting.
sjlplat is offline
post #7 of 20 Old 03-21-2005, 03:43 PM Thread Starter
COJAM
COJAM's Avatar
That's an idea. Do you have an example of one. That may be an idea.
GBD
COJAM is offline
post #8 of 20 Old 03-21-2005, 03:57 PM
sjlplat
sjlplat is offline
post #9 of 20 Old 03-21-2005, 04:00 PM
xeon
WOW! That is totally AWESOME!
My Speedo keeps busting gears and this would be great when I do my Vortec swap! WOW Thanks for the info!
88YJ, 350TBI, 700R4, Atlas 4.3, HP60, 14B (At a mall near you)
Tri-State (NJ-NY-PA) 4x4 Wheeling Group
xeon is offline
post #10 of 20 Old 03-21-2005, 04:06 PM
sjlplat
Somethin' else you engine-swappers might be interested in:
http://www.pirate4x4.com/forum/showthread.php?t=239524
sjlplat is offline
post #11 of 20 Old 03-21-2005, 04:59 PM Thread Starter
COJAM
COJAM's Avatar
that aint cheep is it.
GBD
COJAM is offline
post #12 of 20 Old 03-21-2005, 05:18 PM
sjlplat
Get into those specialty gauges, and it can get pricey.
sjlplat is offline
post #13 of 20 Old 03-21-2005, 05:25 PM
kg6mti
1987 YJ Wrangler
Just for information so that nobody is confused. That electrical connection is not a speed sending unit. That is the vehicle speed sensor. All this unit does is communicate to the PCM that the vehicle is in motion nothing more nothing less. It does not translate into actual speed in MPH.
Experience is what you get when you get what you didnít want.
kg6mti is offline
post #14 of 20 Old 03-21-2005, 06:02 PM
sjlplat
Partly correct -- That is the VSS, but it does more than send a signal that the vehicle is in motion. It sends a signal to the PCM in terms of pulses. The PCM translate the pulses into an electrical signal, which is sent to the speedometer. The speedometer translates the electrical signal from the PCM into the actual speed display.
sjlplat is offline
post #15 of 20 Old 03-21-2005, 06:06 PM Thread Starter
COJAM
COJAM's Avatar
anyway back to my original question. I am not going to use stock guages, tach or speedo. I need a programable speedo because I cannot fit the cable behind the new dash I had made. I need to know if anyone has experience with the sending unit so I can order one up.
Autometer makes a good speedo but I need to know if thier sender will work with my np231.
GBD
COJAM is offline
will cable driven slip yoke work with electronic speedometer? nnojeeps YJ Wrangler Technical Forum 4 10-19-2009 11:49 PM
electronic speedometer calibration: a writeup tcox TJ Wrangler Technical Forum 0 09-08-2008 11:44 AM
Swapping out mechanical speedometer for electronic one. Oorin YJ Wrangler Technical Forum 3 01-31-2008 09:13 AM
Convert AX15/NP to electronic speedometer? Fred007 YJ Wrangler Technical Forum 3 10-25-2007 08:09 AM
Electronic Speedometer on a 91 YJ Mr. Tobes YJ Wrangler Technical Forum 3 10-28-2006 11:22 PM
