Electrical short, engine cranks but won't start... - JeepForum.com
post #1 of 2 Old 10-23-2001, 05:30 AM Thread Starter
JeepDad
My son has a '99 Jeep Wrangler. He was hooking up a subwoofer, turned on the ignition switch, and says he saw the interior lights flash (I think he had the door open) and then go out. The headlights still work, and the starter cranks but won't start. Everything else electrical seems to be out, no dome light, no instrument cluster, no light under the hood.
I got to look at it, (10:00pm in his girlfriend's driveway), we checked all the fuses in the glove compartment, and in the engine compartment, and they all seem OK. I thought it was possible that the fuel pump relay shorted, and swapped it with the horn relay, No Luck!
Where else would we check? Are there fusible links that he could have blown?
Thanks in advance,
JeepDad
JeepDad is offline
post #2 of 2 Old 10-23-2001, 12:42 PM
powjunkie
Where did he connect his amp power cable? Directly to the battery, at the fuse block, somewhere else? Also, when you checked for blown fuses and relays, did you use a meter or do a visual check. Sometimes fuses can look ok, but still be blown.
One thing you can do to see if you're getting spark is pull a plug wire off and see if it arcs to the plug (hold it with something insulated so you don't get shocked).
94 YJ 4", SYE, 33 mud t's on MT classics; 4.10's with Detroit Truetrac in rear
powjunkie is offline
Cranks and Cranks, cranks some more and she wont start. crzylgzz YJ Wrangler Technical Forum 37 12-09-2011 03:44 PM
2.5 cranks but wont start...Cold start SnowdogMarc YJ Wrangler Technical Forum 4 08-04-2009 07:16 PM
4.0L cranks but no start, no roll start flame0086 YJ Wrangler Technical Forum 11 06-15-2009 05:00 PM
My Jeep Cranks And Cranks But No Start!!! b1ack2tar YJ Wrangler Technical Forum 5 01-14-2009 08:23 AM
my engine cranks, but doesnt start TXjeepTJ TJ Wrangler Technical Forum 13 11-08-2006 05:01 PM
