Electrical Short???? - Page 2 - JeepForum.com
post #16 of 28 Old 02-24-2010, 06:11 AM Thread Starter
Elsahara
Originally Posted by laybackman View Post
I have absolutely no idea how/why I typed that into my answer!!!!
hahha I had my girl friend come to read it, cuz i had no clue what you meant. (shes def a mechanically inclined girl too)
She was at a loss too !!!
Originally Posted by idaholtby View Post
To both you and the OP, this sounds to be more of a power issue rather than a ground. Both headlights are individually grounded. If both are going out, then this is more apt to be a power problem. If the dash illumination is dropping at the same time, then for the '88 and '89 model years that have been mentioned, I would suspect a bad fusible link or connection there to.
If just the headlamps are dropping out on these years, then it is likely the headlamp switch, the hi/low dimmer switch or the wiring suppling power to/from all of the above.
i had issues with the fuseable linke on my 90'. def not the same issue. i would guess it could be the switch, as it controls the exterior lights and the interior dash lights. or a ground that is just getting off and on consistency.
thanks to everyones input! i know have some directions to chase.
Elsahara is offline
post #17 of 28 Old 02-24-2010, 07:08 AM
clemsonfan16
Where is the fuseable link?
clemsonfan16 is offline
post #18 of 28 Old 02-24-2010, 07:11 AM Thread Starter
Elsahara
On my 90' it was on the passenger side of the firewall low below and to the right of the battery tray
Elsahara is offline
post #19 of 28 Old 02-24-2010, 07:21 AM
clemsonfan16
Awesome I will check that out. Thanks
post #20 of 28 Old 02-24-2010, 07:46 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I would normally agree with you except that the issue started when she hit a large bump in the road. Both headlights are grounded to the same piece of mertal that is bolted to the frame. If it was loossened then they would lose their ground wouldn't they?
But the same incident could have caused a loss of power if a large plug like the bulkhead connector got loossened up, but that would knock out everything probably. He has some investigating to do that is for sure. I leaned towards bad grounds becasue that is common in older Jeeps anyways.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #21 of 28 Old 02-24-2010, 07:59 AM
Que89YJ
LOL The switches are sooo bad on the YJ if you hit a but you change the switches attitude! Got to go with Idaholtby on this one with a caviot. Check power at the switch first. If you dont have power there then replace the fuseable link. If its there then spend the $30 and an extra $30 for the next big bump you hit and buy 2 light switches!
Que89YJ is online now
post #22 of 28 Old 02-24-2010, 08:06 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
[QUOTE=Elsahara;8954391]Only cut out for a couple of nervous seconds.
They came on and even after a few more back jolting bumps they stayed on.
Are you saying here that the lights are back on now?!? I'm
post #23 of 28 Old 02-24-2010, 08:50 AM Thread Starter
Elsahara
As i quote myself, i stated when i said in the post i made before saying
my head hurts
It happend once, the lights cut out for a few seconds, came on, no engine flutter, never happened again...in the last 12 hours
Elsahara is offline
post #24 of 28 Old 02-24-2010, 08:54 AM Thread Starter
Elsahara
Just driving tonight, hit a rather nasty bump on a set of train tracks and for just a couple second it killed the interior dash lights and at least the head lights. DID NOT effect the engine though.
Hit a few more nasty bumps and it didnt act up but for obvious reasons I dont like it like not being able to see at night
thought i explained it pretty well. my bad tho!!!
Elsahara is offline
post #25 of 28 Old 02-24-2010, 09:13 AM
clemsonfan16
I just talked to a friend and he said that it could be my alternator. Sound legit?
post #26 of 28 Old 02-24-2010, 03:21 PM
GRN_BEAST95
naa i wouldnt suspect the alternator. I say this because even if it was the alternator you would be noticing other driving related problems alot more frequently. Ask me how i know lol. Did you clean up and tighten all your grounds yet? also if you can get ahold of a volt/ohm meter check out the power supply to the headlamp switch.
1995 YJ emerald green
4" RC lift & 2" BL
33x12.5x15 BFG AT's
Green Jeep member 153
Originally Posted by yellojeeper View Post
Guam. I spent a week there one night.
GRN_BEAST95 is offline
post #27 of 28 Old 02-24-2010, 03:50 PM Thread Starter
Elsahara
I agree, doubtful its the alternator, it would show other signs of possible failure. nd no i wont ask you how you know
havent had a chance to tighten or clean up anything. g/f just got home, its raining out and it hasnt acted up since that night so ill wait till im less lazy
tomorrow...maybe.....
thanks for everyone help tho!
Elsahara is offline
post #28 of 28 Old 02-24-2010, 04:06 PM
GRN_BEAST95
haha no problem. well keep us posted if anything comes up.
4" RC lift & 2" BL
33x12.5x15 BFG AT's
Electrical Short...help. JSimmons TJ Wrangler Technical Forum 17 10-26-2008 08:06 PM
electrical short RecoveryRoomRN JK Wrangler Technical Forum 3 01-01-2008 09:25 AM
Possible Electrical Short ? Help ! cshull1 YJ Wrangler Technical Forum 6 10-14-2005 08:56 PM
Electrical short? Anthen27 YJ Wrangler Technical Forum 5 10-05-2005 07:35 AM
Electrical short? yeeha68 YJ Wrangler Technical Forum 4 03-08-2005 08:20 PM
