Electrical Problems With 89 YJ - JeepForum.com
post #1 of 3 Old 05-02-2011, 10:18 AM Thread Starter
Brifr1231
Hey guys I am wondering if any one can help me try to figure this out. Here's my situation or at least what happens most of the time. When I turn the lights on the windshield wipers run and I have removed the dome fuse so the interior lights and radio are disconnected because the radio was turning off whenever I did anything. When I tested for a charge on the body I have 5-6 volts in the body when the lights are on and 1-2 when the lights are off. So somewhere there is a wire putting a charge to the body. I don't know if its a short or a bad ground. Any help is good help. thank you.
MY RIG: 1989 YJ, 4.2l, Black, 4inch Suspension Lift, Bfg ATs around Craigar Soft 8s
-------------------------If it ain't Broke go Break it.--------------------------
Brifr1231 is offline
post #2 of 3 Old 05-02-2011, 05:08 PM
JWELK
You have a bad ground(s). Check black battery lead, and go from there.
Imagine two light bulbs in series. In your case you have several light bulbs, in series with a bad ground connection. If you measure the voltage between the 2 bulbs you will see a voltage if the bulbs are the same wattage, it will equal 1/2 the supply voltage.
Very good to get as far as you did. Even if the cables look good, take the connectors off and clean with a brush and sandpaper. Oh, the connection is bad between the two points where you measured the voltage!!!
Regards,
Jim W
JWELK is offline
post #3 of 3 Old 05-04-2011, 07:10 PM Thread Starter
Brifr1231
Hey thanks for the reply I actually figured it out on my own before you posted but you had the same idea. the first thing I checked was the body grounding strap and that turned out to be on a painted surface so scrapped that down to bare metal and cleaned the strap and it was all fixed. thanks for the post once again.
electrical problems dabjeep YJ Wrangler Technical Forum 0 03-17-2011 06:21 PM
87 yj electrical problems gsxr750 YJ Wrangler Technical Forum 5 01-06-2009 05:41 PM
More electrical problems BC1 TJ Wrangler Technical Forum 37 12-24-2006 08:48 PM
still having electrical problems jayrod YJ Wrangler Technical Forum 3 11-28-2005 11:25 AM
Electrical problems Cullen TJ Wrangler Technical Forum 2 09-17-2002 07:07 PM
