Electrical mystery.... - JeepForum.com
post #1 of 5 Old 07-23-2005, 08:33 AM Thread Starter
Arc
Driving a 95 YJ and twice in the last 6 mo. now when travelling at night I've experienced a total power failure (lights, ign, etc) that only lasts for a couple of seconds then comes back on. I've checked battery leads and alternator and they're all tight and working properly. Seems kind of odd it's only happened at night both times. Any ideas? I'd like to get to the bottom of this before it gets me or the wife to the bottom of a embankment...
Arc is offline
post #2 of 5 Old 07-23-2005, 08:50 AM
Jeepsdontfloat
I'd check the battery positrive connection at the fuse box. The fuse box under the hood has the battery connection on its side make sure theats ok. I broke mine when I changed battweries and didnt find out till the next morning no power start anything.
Nows a good time to check braided ground straps also. If youj replace any be sure to remember the star washer between the strap and frame.
'94 Yj, 4.0, 5 spd manual.
Jeepsdontfloat is offline
post #3 of 5 Old 07-24-2005, 12:33 PM Thread Starter
Arc
checked that out, everything looks fine there and the ground is good as well, damned if I know what's causing this but I'll keep looking
Arc is offline
post #4 of 5 Old 07-24-2005, 02:26 PM
Alfons
I've noticed on Jeep wiring schematics that there's an "Auto-Shutdown" module - I'm not sure of exactly what this does, but it may be something worth looking into.
Alfons is offline
post #5 of 5 Old 07-24-2005, 08:34 PM
Raindem
Are there any trouble codes?
If it ain't broke... break it.
Raindem is offline
ECM, PCM, Electrical mystery svoss YJ Wrangler Technical Forum 23 03-16-2009 07:12 AM
mystery break in the electrical system Dsadinsky YJ Wrangler Technical Forum 15 07-27-2008 07:04 PM
Electrical Mystery Heep TJ Wrangler Technical Forum 1 02-26-2008 11:06 AM
Help with electrical mystery K2Racing YJ Wrangler Technical Forum 5 01-25-2005 07:50 PM
Yj mystery..... 4x4punk YJ Wrangler Technical Forum 11 11-03-2004 07:42 AM
