Quantcast Electrical - Ignition problem...1993 won't turn over - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Electrical - Ignition problem...1993 won't turn over
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 09-22-2009, 12:07 PM   #1
loverocks4013
I have posted a few things already but have yet to receive a response. So I am posting again.
I was driving and my engine light came on and then the Jeep just died. I tried to crank it over and it wouldn't start...it seem like it wanted to but would not turn over.
I changed the fuel pump, the CPS, and the ignition pickup and still having the same problem.
When I turn the key, I can hear the fuel pump kick on, and a friend with a light tester said when I turn the key I get power to the coil, but wuithin a second it is lost.
I can change a lot of things but when it comes to electrical I am out of league.
What is the next course of action I should take to find out what is the problem? Should I change the coil...and the ignition switch? Or could it be something else? I got a price on he Control module...mad expensive, so I am praying that is not it...I checked the ground by the parking brake and that is secured. I am not sure what else to check for/
Like I said, the car wants to start, everything seems to be engaging, I get the radio, lights, I checked the key codes already, the pump kicks on, but it still won't turn over.
Thanks so much ~
Kim
~ Love Rocks ~
loverocks4013 is offline   Reply With Quote
Old 09-22-2009, 12:21 PM   #2
Xtremjeep
I have had past issues with the same symptoms. Sorry to say it was the control module that was my problem.
Xtremjeep is offline   Reply With Quote
Old 09-22-2009, 12:24 PM   #3
MJMPC
Have you checked for codes ?
MIKE
http://www.dav.org/
MJM Powder Coating
Elizabethtown Ky.
http://www.cityprofile.com/
MJMPC is offline   Reply With Quote
Old 09-22-2009, 12:28 PM   #4
RebuildRookie
You checked the fuel pump ground on the sidewall of jeep by the parking brake correct. Not on the parking brake itself (thats the EBRAKE light on your cluster to let you know its engaged)
[FONT="Century Gothic"][B]I'm a more proactive person.
You spray the ants before they get in your house.
You plant the crops before you starve.
And you keep the terrorists in check before you get your *** blowed off.[/B][/FONT]
RebuildRookie is offline   Reply With Quote
Old 09-22-2009, 01:03 PM   #5
loverocks4013
I checked for the codes...one was for A/c which I don't have and the other was for EGR. I did check the fuel pump ground where you said and it all checks out.
~ Love Rocks ~
Old 09-22-2009, 01:26 PM   #6
loverocks4013
how do you know when the ECM is shot? Should I try something else before I purchase that? I just checked into that and its not easy to return, since they program it according to your VIN # and model, etc. Any suggestions on what I should do BEFORE I go and get the ECM? I am doing this on my own right now, so any further help or info would be great! thanks guys!
~ Love Rocks ~
Old 09-22-2009, 02:06 PM   #7
RebuildRookie
You could pull the ECM and take the cover off and look at the board and tell if you have any fried lead-connections-wires(whatever there called there the silver lines on the board that goes to the diodes(black barrel looking things)) I cant fix it but many electrical folks can if it is FRIED.
Old 09-22-2009, 02:42 PM   #8
YJdad
YJdad's Avatar
CPS? Crank Position Sensor?
94' YJ Stock 2.5L - tornado resistant up to 100 yards / BFG 30x9.5x15 / Herculiner / Stereo console - Currently parked for overhaul
98' ZJ GCL - Stock V8
75% of the world is covered by water, the rest is covered by Jeep!
YJdad is offline   Reply With Quote
Old 09-22-2009, 09:44 PM   #9
Mean Max
Mean Max's Avatar
BTT
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Mean Max is setting up his Jeep shop!
Picture history of my progress here.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Old 09-22-2009, 10:49 PM   #10
4LarXedo4
did you check for spark at the plugs yet? depending on whether the plugs are actually firing could take this a few different ways.
4LarXedo4 is offline   Reply With Quote
Old 09-23-2009, 08:08 AM   #11
loverocks4013
hey guys! thanks for the help...jsut getting these messages now, I will check all that you recommended and get back to you with my results.
Mean Max...LOL what did you mean by your post...BTT?? LOL
~ Love Rocks ~
Old 09-23-2009, 09:02 AM   #12
Mean Max
Mean Max's Avatar
BTT = Bump The Thread, to get it back up to the top of the list.
Max
Old 09-23-2009, 09:04 AM   #13
sprngrider
My YJ did the same thing, it turned out to be the ecu causing the problem. I was constantly replacing sensors, but the only thing that fixed my stalling issue was a remanufactured ecu.
1994 2.5L WRANGLER S.
sprngrider is online now   Reply With Quote
Old 09-23-2009, 09:08 AM   #14
idaholtby
What codes are stored (what numbers showed up)? Your rig does not have an EGR system.
idaholtby is offline   Reply With Quote
Old 09-23-2009, 01:40 PM   #15
loverocks4013
yeah I figured out that I do not have EGR and the only codes that came up were for the EGR and the A/c both of which I do not have. I have replaced everything pretty much. I even went and got a new coil and tested it but it still did not turn over, so it is not that...so I am returning it.
I wasn't getting a spark to the plugs before, which is why I replaced the ignition pickup, a little nervous to check that now...being I am by myself...and have never done that...haha!
So if there is no spark should I change the plugs and the wires first? I know that they are only two years old, so I really didn't think that was the problem, but now I am beginning to wonder.
I took out the washer reservoir and I can see how to remove the ECU but a little nervouse about doing it as I have noticed there are wires attached to it behind a small rectagular box on the bottom right hand corner...can anyone give me a clue how to remove the box so I can check to see what it loks like inside?
I also bought an inginiton switch, buuuut I hear that is a nasty job and if it is not that and i tis the ECU I realllly do not want to spend time l;earning how to replace it...any thoughts on that guys?
And btw, thanks for all the help
Kim ~
~ Love Rocks ~
Glock Forum
