Electrical Help: Brake light only works if i turn hazards on and off - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Electrical Help: Brake light only works if i turn hazards on and off
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 05-11-2014, 10:49 PM   #1
Jeepineveryday
i'm stumped...
both of my brake lights DO work but the left one seems to stop working for some reason. the only way to get it to work is to simply pull the hazard light button/switch to the on position then turn it back off. it works for a very short time. maybe a few miles? a few minutes? a few brakes at stop lights? whatever the case, it's not long at all.
thoughts or ideas?
thanks in advance
Jeepineveryday is offline   Reply With Quote Quick reply to this message
Unread 05-12-2014, 07:55 AM   #2
rodgers3
Sounds like a ground or a short.
Do you have trailer wiring? I do but the po had done a very shoty job of just cutting insulation and wraping the trailer wires around and re tapeing. That has sinc been fixed lol.
rodgers3 is offline   Reply With Quote Quick reply to this message
Unread 05-12-2014, 11:01 AM   #3
Que89YJ
X2 with Rodgers. Check the tail light housing. They pull ground through the studs used to mount the housing. Make sure they are clean and making good contact.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 05-12-2014, 02:48 PM   #4
piotrsko
Bit of contact cleaner into the switch might help also.
piotrsko is offline   Reply With Quote Quick reply to this message
Unread 05-12-2014, 03:26 PM   #5
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
OP, have someone watch the tail lights while you have your foot on the brake. Jiggle the turn signal stalk and mess with the four way switch. I am thinking turn signal switch...
Mark
Smoke em if you got em!
Click here
Mobile_Homie is offline   Reply With Quote Quick reply to this message
Unread 05-12-2014, 06:01 PM   #6
Cobra Jeep
Yep, its the turn signal switch. I had the same issue in my YJ a few years ago. Replaced the turn signal switch and it fixed. The contacts are worn and, well, not making good contact anymore.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, WJ knuckle/brake conversion, hydroboost. Warn M10000 winch. Hope to some day build a stroker for it.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Future mods: NV4500, NP205, high pinion D60 front and smooth bottom D60 rear, e-lockers front & rear. SOA with 35X12.50's
Cobra Jeep is offline   Reply With Quote Quick reply to this message
Unread 05-12-2014, 06:31 PM   #7
Jeepineveryday
good info. will mess with it now and see if i can figure anything out. will post results. thanks ya'll.
