Electrical-Gauge/Buzzer/Reverse Lights Circut - JeepForum.com
post #1 of 5 Old 08-19-2009, 07:37 PM Thread Starter
BadAddetude
Here it is:
Fuse #9 on the interior panel, 15A, labeled 'IGN/LPS'. I keep popping the fuses. The problem is, it is very sporadic. Last weekend I put 150 miles on a single fuse, and on a short 2-mile run down the street it popped.
I have a serious hot wore going to ground, as I can hear the fuse blow, with relative authority. I've searched this, and it showed that several others have had similar symptoms, but were vague with a solution to it.
My question is: What (or where) could the short be that is causing the fuse to blow?
1995 YJ: 4.0, 700R4, 231 C/J case, TeraFlex SS SYE/CV shaft, 8.8 with 3.73 gears, 136 Amp Alternator, Trans Cooler, Pavement Ends Flip-top/H-T, 2'' BDS Suspension Lift, MORE 5/8' Greasables, Sony GT-210 Xplode Head.
Under the Knife! See the build thread:
BadAddetude is offline
post #2 of 5 Old 08-19-2009, 09:53 PM Thread Starter
BadAddetude
Get a bump for the Night crew here...
post #3 of 5 Old 08-20-2009, 10:07 AM Thread Starter
BadAddetude
Nobody wants to help me out here?
post #4 of 5 Old 04-09-2013, 03:37 AM
Prokyone
Did you ever get your problem fixed? I have a 92 YJ which is having a similar problem. I noticed my volt meter on the dash goes down quit a bit when I put my jeep in reverse.
Prokyone is offline
post #5 of 5 Old 04-09-2013, 03:34 PM
JWELK
You are going to have do some circuit tracing. Do you have a soldering iron and meter? If not get them. 30 watts will do. Home Depot has a good selection, gas is nice as you can use them in the field.
You will need a back up bulb and appropriate socket.
After you have acquired these, get one of your open (blown) fuses and look for the two metal tabs on the top. Solder the back up light socket to these tabs. Install the light bulb and insert the fuse into the #9 slot. When the light lights you have your short. So now start wiggling wires, you already know what stops working when the short occurs. This may take some time look in obvious places where the wire may chafe.
Let us know what you find
Regards,
Jim W
JWELK is offline
reverse light switch wires cut/ no reverse lights Floppy YJ Wrangler Technical Forum 9 02-16-2014 12:52 PM
Lights on buzzer? 91 Mint Sahara YJ Wrangler Technical Forum 3 12-18-2010 12:10 PM
No reverse lights and dash lights bright up barefoot352 TJ Wrangler Technical Forum 2 07-07-2009 08:26 PM
autometer oil pressure gauge reading in reverse? 1989sahara YJ Wrangler Technical Forum 2 04-04-2009 04:26 PM
Gauge warning lights - electrical Mr YJ YJ Wrangler Technical Forum 1 12-24-2006 12:39 PM
