Quantcast electrical 4wd switch/wiring write up - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > electrical 4wd switch/wiring write up
Old 04-14-2009, 11:03 PM   #16
YJSlave
How does the switch at the vaccum motor work on the 93, I replaced my axles with them and my set up was the old vaccum switch. How can I get my light to work in the dash?
YJSlave is offline   Reply With Quote
Old 04-15-2009, 07:12 AM   #17
dodger889
lost in the woods
dodger889's Avatar
Originally Posted by kirksjeep View Post
The older YJ's had a clock in that slot of the dash, but nothing lights up in the bottom part of that slot. I'm not sure what the Jeep engineers were thinking.
Your 4x4 light is in between the turn signal lights above the steering wheel with the rest of the idoits light.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline   Reply With Quote
Old 04-15-2009, 09:00 AM   #18
crb577
the vacuum switch works the same way just completes a circuit at the shift fork to make the light turn on. You replaced axles with chromo's? or one piece passenger? etc... a little help here if they are solid axles like mine are just do the same thing like I did. It will work just fine.
1993 Jeep Wrangler
4.0L Tom Woods rear HD shaft
D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,5" BDS, homemade greasable boomerang shackles, SS braided lines, rubicon flares, 1" prothane body lift, 35" TrXus M/T, smitty built XRC, armor and a paint job soon to come.
crb577 is offline   Reply With Quote
Old 04-15-2009, 09:02 AM   #19
crb577
Originally Posted by provinT13 View Post
Would have been nice if there was a clock under there. In the older models if the cppco was where the 4wd is now, where was the 4wd?
also could've been nice if they had a "low" portion there on the bottom part that would be cool. but oh well
1993 Jeep Wrangler
Glock Forum
