Electric speed sensor to speedometer - JeepForum.com
post #1 of 8 Old 06-13-2013, 07:47 AM Thread Starter
Daretobesquare
I am having a hard time getting my speedometer working.
Here's what I got.
I have the electic speed sensor with 3 wires. Black, orange & white
The supply 5v is dark blue, with a brown return wire to the PCM/speedometer.
I can not get the speedometer/odometer to work. The tach works fine.
Tried cleaning the ribbon behind speedometer, even jumped 12v and ground To try and get it to work.
I was having power supply issues, while grounding the speed sensor(black wire) I realized the sensor is already grounded via the transfer case.
Should I still run a direct ground to frame ?
I found the orange/white wire gojng to tach/speedometer cluster, seem to be getting signal there. Any help is appreciated.
Thanks
Daretobesquare is offline
post #2 of 8 Old 06-13-2013, 09:29 AM
idaholtby
Did your speedo quit on it's own or did this come about after other maintenance work, such as on the t-case? Have you tried removing the VSS and driving it with a drill? The VSS is rotationally clocked when it is installed on the T-case. It must be rotated to match the tooth count of your drive gear(markings are on the t-case for this purpose). If not, the gears will not properly align and thus no signal for the speedometer.
idaholtby is offline
post #3 of 8 Old 06-14-2013, 01:42 AM Thread Starter
Daretobesquare
Been searching all over & trying to make sense of it did the sye a while ago with the drive train swap, been ignoring it until now. Once I started screwing with it, it's got me rattled. The 95 already. Had the mechanical speed sensor with the electric output to the speedometer, that worked fine. (2 wire system)
So I got the new speed sensor with the sye kit and here I am. Doesn't seem to be ajustable, only the 10mm bolt to the mega short sye housing. Tonight I realizes the ribbon has some stress marks in it. Could also be contributing to problem... I ran independent 12v ignition power, ground, and input wires to speedometer. Hooked it back up to speed sensor ....nothing
Than unhooked and tried to figure out if the speedometer is even working.....couldn't and haven't seen the needle move since I still had the 2.5l in it.
post #4 of 8 Old 06-14-2013, 03:11 AM
Mark05059
Take the adapter out.. Turn the key to on (dont have to have the engine started) put the adapter in a drill and spin it. Watch the speedometer. If it works then you need to clock the gear correctly.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 8 Old 06-14-2013, 06:54 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
OP, do you know what he means by 'clock the gear'? It's probably the most important part of working on a YJ speedo.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #6 of 8 Old 07-19-2013, 05:52 PM
glturner39
I don't know what he meant by clocked. My 93 started acting up today. Sometimes stuck on 0 sometimes 25.
glturner39 is offline
post #7 of 8 Old 07-20-2013, 07:03 AM
JeeperDon
JeeperDon's Avatar
Clocked means there are three rotational positions for the main plastic housing being in the aluminum case. That main housing is actually an eccentric, the gear spindle is not in the center of the housing. The little Y shaped single screw clamp has small tails at the top of the Y that go into small slots in the plastic housing. The side of the housing is marked with each of three tooth count ranges. You have to pick the right range (clocking) to get the worm gear to engage properly.
Web Admin for
post #8 of 8 Old 07-20-2013, 05:20 PM
Mark05059
Thank you Don for explaining what I should have explained to begin with.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
