Electric help for starting issue - JeepForum.com
post #1 of 1 Old 02-24-2010, 10:12 AM Thread Starter
NJscott
I want to make a temporary ( possibly permanent) starter circuit to see if mine has crapped out. I have a push button starter switch, im fairly certain i cant power the circuit directly from the battery thats why the original has a relay. Could someone help me out with any relays or fuses I should incorporate. It doesnt have to be pretty i just want to bypass the current set up completly for diagnostic reasons. thanks.
90 islander ( de-stickered)
webber 32/34
ford dist. cap & rotor
daystar 1" bl
1.25" booms
NJscott is offline
Starting Issue, help please.. gregdean13 TJ Wrangler Technical Forum 6 02-11-2010 11:20 AM
Electric power loss while starting my TJ unclemot TJ Wrangler Technical Forum 1 09-10-2009 06:07 PM
99' TJ Starting Issue firemanleeman TJ Wrangler Technical Forum 4 02-10-2008 04:43 PM
Suspension lift issue with electric sway bar disconnects? nd95450 JK Wrangler Technical Forum 7 12-04-2007 11:32 PM
Another TJ Starting issue K Rock Jeep TJ Wrangler Technical Forum 8 12-05-2004 03:26 PM
